Markus56 Posted April 17, 2012 Share Posted April 17, 2012 Hey guys, Doing a 4" lift on a 91 legacy with a 4EAT, and it occured to me that the speedo cable will not be long enough to reach. Never had a problem with that before when i was lifting gen 2s and 3s. can i take a cable off of a different model? or do i need to buy a gps. Thanks! Link to comment Share on other sites More sharing options...
987687 Posted April 17, 2012 Share Posted April 17, 2012 Markus56 said: Hey guys, Doing a 4" lift on a 91 legacy with a 4EAT, and it occured to me that the speedo cable will not be long enough to reach. Never had a problem with that before when i was lifting gen 2s and 3s. can i take a cable off of a different model? or do i need to buy a gps. Thanks! The automatic transmission won't work properly without a speedo cable. It upsets the computer, and it won't shift. It's like having the governor disconnected on an old tranny. I'm pretty sure a manual cable is longer because it has to go half way back on the transmission, not just to the front diff. Link to comment Share on other sites More sharing options...
MilesFox Posted April 17, 2012 Share Posted April 17, 2012 at least in an ea82, the manual trans speedo cable is longer because the speedo is mouned on the side rather than te top. you might get by with an MT cable. this is an idea. I would have to confirm this with ej's Link to comment Share on other sites More sharing options...
Markus56 Posted April 19, 2012 Author Share Posted April 19, 2012 bump. any other folks know? Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 20, 2012 Share Posted April 20, 2012 How do you know it won't be long enough? I've coaxed extra length from wires/cables before by moving their mounting points and rerouting them. I'd even go so far as to drill a new hole in the firewall to move where the cable comes through if needed. Perhaps it can be run inside the firewall and run out much lower down, like on top of the tunnel? Link to comment Share on other sites More sharing options...
Markus56 Posted April 21, 2012 Author Share Posted April 21, 2012 thanks! i will try that Link to comment Share on other sites More sharing options...
