thealleyboy Posted April 18, 2012 Share Posted April 18, 2012 Hey Guys: I had a mishap recently where the driveshaft on my 97 Impreza 5sp sedan gave out - also cracking the tanny case in the process. I found another 5 speed, and now I'm trying to locate the right driveshaft. Does anyone know what years & models will work in my car? Is this a 5sp Impreza-specific driveshaft, or will the Legacy (or EA82?) work as well? thanks!! John Link to comment Share on other sites More sharing options...
Caboobaroo Posted April 18, 2012 Share Posted April 18, 2012 I'm almost positive that the legacy driveline will work but the EA82 will not. Link to comment Share on other sites More sharing options...
ShawnW Posted April 19, 2012 Share Posted April 19, 2012 I have used this logic in the past and it hasn't burned me yet. The chassis type (Impreza/Forester or Legacy/Baja/Outback is the back half of the shaft. The transmission is the front half. Most of these are 2 piece with a flange you can unbolt in the middle. The Ea82/Loyale series are just slightly different. In a pinch they might work but long term isn't good. I have these in stock if you just need a part of a shaft and can't find one local. Link to comment Share on other sites More sharing options...
thealleyboy Posted April 19, 2012 Author Share Posted April 19, 2012 Thanks guys!! Shawns rule of thumb makes a lot of sense - especially if the legnth of that back section is the same between two and four door Imprez models appreciate the feedback... John Link to comment Share on other sites More sharing options...
johnceggleston Posted April 19, 2012 Share Posted April 19, 2012 usually the there is a difference between the AT / MT rear sections, at least on the lego models. but i don't know if the rear lego shaft it the same as the rear impreza shaft. you can search what you are looking for on http://www.car-part.com, and see what matching shafts they return. Link to comment Share on other sites More sharing options...
