mikewilke77 Posted April 19, 2012 Share Posted April 19, 2012 I've got a 95 legacy wagon with an auto trnny. It occasionaly dies when I stop at a red light. When it does this to me, it will not start for about 5 min. It just turns over seemingly not getting spark. Then all of the sudden it starts and runs fine. Never any problems while in forward motion. Please help??????? Quote Link to comment Share on other sites More sharing options...
Durania Posted April 19, 2012 Share Posted April 19, 2012 First question, do you have any check engine codes? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted April 19, 2012 Share Posted April 19, 2012 consider the engine temp sensor on the back of the water passage pipe under the intake. Quote Link to comment Share on other sites More sharing options...
mikewilke77 Posted April 20, 2012 Author Share Posted April 20, 2012 no cel. Also I forgot to mention that I just swapped the tranny. The problem also existed with the old transmission. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted April 21, 2012 Share Posted April 21, 2012 This is not a Transmission issue, it is most likely the Coolant Temp sensor on the Coolant cross over like Fox said. I had this issue with my '95. I also had a bad Knock sensor and Cam sensor which did not help the matter. The first time it stalled I thought I was out of fuel Ha! The coolant temp sensor is about $40 bucks from most parts stores. It is kinda of a PITA to get to because the IAC (Idle Air Control Valve) is in the way, but you "can" get to it. I did Take care, -Tom Quote Link to comment Share on other sites More sharing options...
mikewilke77 Posted April 21, 2012 Author Share Posted April 21, 2012 Thanks for the advice. Ill try temp sensor and get back to you with results. Thank you to everyone who shares their time and talent with all of us novices. This site has saved me a fortune in repair bills. Quote Link to comment Share on other sites More sharing options...
bru73 Posted April 21, 2012 Share Posted April 21, 2012 temp senser,iac most likely valve adjustment Quote Link to comment Share on other sites More sharing options...
