1-3-2-4 Posted April 22, 2012 Share Posted April 22, 2012 I'm not sure if you call it binding or dragging since I've never been in a car that dragged. Anyways I notice is the most when say I turn the wheel say two times to the right or left to park in a space or whatever it feels like the whole car wants to slow down more then normal. For people that have binding do you have any sounds? Link to comment Share on other sites More sharing options...
lmdew Posted April 22, 2012 Share Posted April 22, 2012 Normal stuff to check first: - Tires Matched - Tire Pressure If all is good, the viscous unit in the trans is the most likely problem Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 22, 2012 Share Posted April 22, 2012 (edited) ^^^ yep - hope it isn't the center diff. Tires must be same model/inflation and wear (to within 2 or 3 32") you might get under there and check axles and u-joints too, but those are longshots. Edited April 22, 2012 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 22, 2012 Author Share Posted April 22, 2012 I was just curious it might be the brake on the passenger side as well.. if it is the center diff then no big deal since I just wanted to know if it was worth saving when I pull the transmission Link to comment Share on other sites More sharing options...
