Axle boot choices.
So the pass inner boot on my GL keeps getting cooked, probably the cat is getting too hot and cooking it, or whatever. I'll make sure it's not overheating and make a shield.
But that's not the point here, I need to replace the inner boot. I could go buy the cheapest one on rockauto like I usually do OR... Is there a better choice?
Is there a boot that has more flex, heat resistent, wear resistent, or whatever that I should try? Or are they all more or less the same
Also, I know automatic axles have different splines, but are the boot diameters the same? Ie. will an auto boot work on a manual axle.
I had the same problem with the boot near the catalytic converter on my turbo motor. I kept going through regular rubber boots, and then I bought a silicone one and it's been great for a few years. The silicone one is softer so you'll need to be careful on the tightening of the clamps, but it's very flexible and heat resistant.
I should have the part number at home, I'll post it up this evening.
that's good to know, how can you tell which ones are silicon?
there are companies that make more robust CV boots though i've never heard of them being used on Subaru's i can't see why it would be a big deal to find one the right diameter on each side and call it a day. you can google them and contact them if you wanted.
Ah, it's probably the same thing if it's the same with EJ.
I'm pretty sure it is, just curious. I've found some better kits listed as automatic not as manual. So I wasn't sure. I broke the retainer ring taking it apart (it was wicked stuck and bent up). So I want a kit that comes with one of those...
You can get good Boot clamps at NAPA. Get the kind with the ribs/teeth. They are very easy to install and work great.
Tho closest kit is in Ohio, not only is it expensive, they want $10 shipping. So it's faster, cheaper, and easier to order it online.
Well, see if you can get boot clamps like this. They are SOOO much easier to install with simple tools (Pliers and or Wire cutters to crimp the locking end)
http://www.rockauto.com/catalog/moreinfo.php?pk=1029721
Cheers.
That's what's on there now. I can take them apart and put them back together without ruining them. I have a tricky trick :)
I mean the retaining ring that keeps the axle together. The one you have to pop out to get the cup off the axle assy. That was stuck in the groove and bent up coming out.
Presslab:
Thank you!
I'll look that up.
TheLoyale:
I haven't taken the snap ring off yet that holds the race/balls on. But I did notice that a lot of kits include that, so I figured it might be a common situation for it to break/bend.
kits i've bought off of Rockauto sometimes don't have the right size rings/circlips in them so i just reuse them. if you're buying it for that hardware make sure it's going to have the right one.
