rogerracer Posted April 24, 2012 Share Posted April 24, 2012 (edited) On almost every take off from a stop, I hear a clunk noise from R.Rear. It occurs at 10-15 mph. It doesn't seem to matter if the park brake has been applied or not. It sounds like something is unlatching as the car speeds up. Any ideas? It's a 3.6r Thanks in advance. Edited April 24, 2012 by rogerracer additional info Link to comment Share on other sites More sharing options...
Legacy777 Posted May 2, 2012 Share Posted May 2, 2012 It's possible something is loose at the rear end. Probably the best thing to do is jack up the car and look around to see if you notice anything loose or not where it should be. You can try pulling on a the axles/rear diff a little bit to see if something is loose. Make sure you've got the car on jackstands. If you don't find anything, I'd suggest taking it to the dealer. It should still be under warranty. Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 2, 2012 Share Posted May 2, 2012 Take it to the dealer. The car is too new to have worn bushings or suspension parts. If somethings loose it's a defect or a loose bolt. Link to comment Share on other sites More sharing options...
