Prwa101 Posted April 25, 2012 Share Posted April 25, 2012 I'm looking into make a locker for Subaru and am in need of two or more diffes one from each to compare and measure. To mock up a working locker in solid works for an ea82, for further development if it takes off. Student at Psu and mhcc and would buy some but can't afford to. Thanks guys! -Prwa Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 25, 2012 Share Posted April 25, 2012 EA and Legacy diffs are all the same except for stub style. Internally they are identical and if you made a locker for one it would fit both. I have a crapload of 3.7 and some 3.9 diffs and diff parts in my shed. Probably will never use any of them due to their ratio's - almost any conceiveable replacement I would need would be 4.11 or 4.44 and probably for a '95+ that doesn't use the bolt-in stubs. Anyway - you can have whatever diff parts you want - just haul em off. GD Link to comment Share on other sites More sharing options...
Prwa101 Posted April 25, 2012 Author Share Posted April 25, 2012 EA and Legacy diffs are all the same except for stub style. Internally they are identical and if you made a locker for one it would fit both. I have a crapload of 3.7 and some 3.9 diffs and diff parts in my shed. Probably will never use any of them due to their ratio's - almost any conceiveable replacement I would need would be 4.11 or 4.44 and probably for a '95+ that doesn't use the bolt-in stubs. Anyway - you can have whatever diff parts you want - just haul em off. GD Awsome! I'll take em! Pm sending! Link to comment Share on other sites More sharing options...
Prwa101 Posted April 30, 2012 Author Share Posted April 30, 2012 EA and Legacy diffs are all the same except for stub style. Internally they are identical and if you made a locker for one it would fit both. I have a crapload of 3.7 and some 3.9 diffs and diff parts in my shed. Probably will never use any of them due to their ratio's - almost any conceiveable replacement I would need would be 4.11 or 4.44 and probably for a '95+ that doesn't use the bolt-in stubs. Anyway - you can have whatever diff parts you want - just haul em off. GD I think you pm's are full. Havnt heard from you. Thanks -prwa Link to comment Share on other sites More sharing options...
