86subaru Posted April 26, 2012 Share Posted April 26, 2012 willl a hub bearing knuckle from a 98 forester fit on a 95 legacy wagon , just asking Link to comment Share on other sites More sharing options...
johnceggleston Posted April 26, 2012 Share Posted April 26, 2012 yes, as long as it has the ABS if needed. Link to comment Share on other sites More sharing options...
idosubaru Posted April 26, 2012 Share Posted April 26, 2012 when interchanging knuckles, 90's rear (and some 2000's) EJ knuckles are the same with these considerations in mind: 1. match rear drum or disc brakes. some legacy brightons and imprezas had rear drums. forester and i think all 95 legacys have rear disc so yours is clear. 2. ABS or non-ABS. you can install ABS knuckles in non-ABS cars, just leave the sensor out. and you can install non-ABS into ABS cars if you don't want the ABS to work. LOL SVX and 05+ STi knuckles won't work as they have the 5x113 lug pattern instead of the typical EJ 5x100. Link to comment Share on other sites More sharing options...
86subaru Posted April 27, 2012 Author Share Posted April 27, 2012 my 95 has rear drum brakes, the forester part is rear disc Link to comment Share on other sites More sharing options...
Mike104 Posted April 27, 2012 Share Posted April 27, 2012 While not as good as someone who has actually done the part interchange being asked about, one source of info is the opposed forces website. I usually find the part number for my car and then click on the part number and it gives a list of the cars that the part number was used on. For example for a 98 Forester it give P/N 28411AA010 for the rear left knuckle. If you click on the part number it gives you this page: http://opposedforces.com/parts/info/28411AA010/ and you can open the list for the car you are thinking of getting the part from and see if it was used on your car. Link to comment Share on other sites More sharing options...
MilesFox Posted April 28, 2012 Share Posted April 28, 2012 0ur 97 forester has drum brakes in the rear. Link to comment Share on other sites More sharing options...
3Pin Posted April 28, 2012 Share Posted April 28, 2012 Miles, I thought 98 was the first Forester?? Link to comment Share on other sites More sharing options...
86subaru Posted April 28, 2012 Author Share Posted April 28, 2012 dam 2000 went down , will the rear disc set up work on a 95 , drum to disc? 2000 to 95? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 28, 2012 Share Posted April 28, 2012 You can swap over to rear discs without problem but for it to be totally correct you will need rear disc parking brake cables for the '95. Due to length and mounting point considerations it is unlike that the '00 cables will work. The drum cables will not fit the backing plate correctly but can be made to work if you want to grind the end down so it fits into the backing plate and adjust the cable tension, etc to compensate. GD Link to comment Share on other sites More sharing options...
86subaru Posted April 28, 2012 Author Share Posted April 28, 2012 ok Link to comment Share on other sites More sharing options...
