Lachlan Posted April 30, 2012 Share Posted April 30, 2012 Upon removing my EA81 intake manifold, the crossover pipe managed to donate its contents to the cylinders. What's the best way to dry them out without pulling the whole thing apart? Link to comment Share on other sites More sharing options...
skishop69 Posted April 30, 2012 Share Posted April 30, 2012 Simply pull the spark plugs and crank it over for 30 seconds twice. Shoot some carb cleaner in the intake ports on the second time. Good to go. Link to comment Share on other sites More sharing options...
987687 Posted May 1, 2012 Share Posted May 1, 2012 most important thing is to not leave coolant in the cylinders. It'll rust the walls and rings. Get it out and dump some oil in there to keep it from rusting. Or just run it. Link to comment Share on other sites More sharing options...
Indrid cold Posted May 1, 2012 Share Posted May 1, 2012 kill the spark from the coil to distributor, if you crank over after injecting a flammable solution... I had it jet out, hit the dangling plug wire arcing to the block and instant fire! hahahaha... Link to comment Share on other sites More sharing options...
Lachlan Posted May 1, 2012 Author Share Posted May 1, 2012 Thanks! A puddle of coolant, and no fires! Link to comment Share on other sites More sharing options...
