New Project.. 2" now but 8" later....Lifted D/R Impreza (Turtle)
one eye
So as a few of you have seen in my other thread Im going to be lifting the newest Subaru I have its a 94 impreza Mostaru, (Brian) met a guy down in Oly that needed it gone fast, like fast, fast, so he called me up and I picked it up for pretty Figgin cheap, The VSS is messed up on it but thats not to much of a biggie but I was able to get her home in Limp mode, jsut and FYI If you ever have and OBD1 impreza pull the MAF sensor plug and that will put it in limp mode ..........
tn?sid=1715842260&mid=AMzjimIAADQmT6ikAADrYQM5c80&midoffset=2_0_0_1_5799209&partid=2&f=1259&fid=Inbox&w=637&h=480&httperr=1
This is how it started off......
The I did some stuff to it............
2.jpg?partExt=.jpg&outquality=56&rand=1628422553291962286&ext=.jpg&limitsize=600,800&inviteToken=BEDr2kzMYY5QczKLLhsk
and this is it for the time being........ got bored last weekend and cut some 2" blocks 8* in the front and straight in the back With the Help of RickDonkUless (Rick) and El Presidente (Josh)......... then put a set of 27 on the wheels it came with, seems to drive and go just fine.........
This is it now......
tn?sid=1715842260&mid=AMzjimIAABL3T6ihEAgNUS3V0ho&midoffset=2_0_0_1_5797384&partid=2&f=1259&fid=Inbox&w=637&h=480&httperr=1
As for the build I plan on a 6"body lift and 8" struts, so pretty much like butters, but with a Heater and Power Steering, looking to run 31X1250X15's on some wider wheels........... There will be a D/R put in it too. so there is a bit of work to do but it will be at WCSS, As for everything that happens with this Im going to keep updating it but there are few other things that need to be wrapped up in the shop before I clogg it all up for a few weeks with this....It going to be green and of course yellow, it will be named Turtle......
Jeff
Edited by one eye
You should EJ it.:grin:
I saw that you where the first one to reply and I new you went with EJ it or EA81 it.... lol
BTW Yotes move on...... one more series and they are in the Cup Eah?...
Jeff
  • 1 month later...
  • 2 months later...
Well not to dig up old threads but this bad boy is at my place again after sittin out at my parents for a couple months, Let the Build begin.......... D/R is ready need one FWD axle and the flywheel drilled but other than that it ready.....
Jeff
It's not at all entirely an over-the-top assertion nevertheless the fact that in medical trials the anti-impotency overcome Cialis has emerged to generally be a highly effective erectile dysfunction treatment in people experiencing prostate most cancers! Using the emergence of this certain Cilais advantage, the drug may be evolved for a wholesome therapy of douleur impotency along with additionally it is clear the therapy of impotency or erectile dysfunction is feasible in just about all situation. Exactly what is important is that the sufferers must not shrink back within the problem and as an alternative need to consider to root out the problem at the earliest.
Buy viagra online Viagra hawaii
That you are clearly mindful of the helpful effects shown because of the FDA approved drug Cialis on erectile dysfunction patients. It functions by accelerating sleek blood circulation into the penis and helps make it effective at placing off erections essential for sexual activity in between companions. Along with you are also aware of the point that Cilais stays while in the procedure for a complete 36 several hours that is a novel advantage presented only by Cialis and none of its other competitors.
Viagra for women uk Buy original viagra
So, exactly what is stopping you from procuring Cialis, just head to some health practitioner and start off your erectile dysfunction treatment? Remember that impotency not just makes the intercourse everyday living of the person sterile but can also be able to wreaking catastrophe with your general lifestyle. Looking at the gravity in the situation, you need to adopt a cautious perspective toward daily life; you can start by finding hold of Cialis prescription in the medical doctor.
Buy viagra paypal Securetabsonline com Viagra Free Pills
When you begin your ED remedy with Cialis, the drug would present its effects therefore you could well be substantially relieved of erectile dysfunction. It is possible to consider Brand viagra online canada empty belly at the same time as on a full stomach as well as the drug would remain similarly powerful on you!
sweet, old school subarus + viagra. Am i the only one that finds this funny?
  • 2 weeks later...
Yesssss. This is going to be sick. I'm looking at puttin a dual range in my impreza so I'm gonna be following this! Do you know how much the driveline will need to be lengthened? From my reading I haven't been able to find that out. - Ryan
Edited by wagonryan
Yesssss. This is going to be sick. I'm looking at puttin a dual range in my impreza so I'm gonna be following this! Do you know how much the drive shaft will need to be lengthened? From my reading I haven't been able to find that out. - Ryan
I think if anything ill cut the first part of my drive line in front of the carrier bearing and shorten the first part there... Ea is like 4" longer than the impy one ....i think...igot it mesured and written up on the wall of notes in the shop....
  • 1 year later...
Well This now has a set date to be built and done..... Oct 12,13,14th this thing will be growing up , Brian (Monstaru) and I will be hitting it hard for those three days, I have all the parts and its Build time....... I Just need to use another of my 500 cars as a comuter while we do this............
Jeff
  • Like 1
