I have a 2002 Forester Automatic with some shifting issues.
I had the codes ran at Autozone and it came back with:
P0732, P0733 and P0734.
Is there a way to read codes from the TCM for better explanation of the trouble? how?
Or should I just replace the TCM?
Any thoughts or ideas would be appreciated.
Canobd2.com
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
This one might take some work. I would almost recommend taking it to a dealer. A scanner that can read sensor outputs will help here, since this can be a throttle position sensor or Speed sensor issue.
This can also just be wiring or a poor connection somewhere in the harness to the ECU/TCU.
