92_rugby_subie Posted May 10, 2012 Share Posted May 10, 2012 Im a bit confused here... my first clock kept shorting out, so it got resoldered, but then didnt turn on... Then a completely different clock got put in, and only works when I push the buttons, the screen turns on but then shuts off when button not pushed... Problem? Solution? Noticed the wiring behind my glovebox has this: Theres 2 red wires, one with a green stripe on it... that doesnt seem to have a spot on the new clocks, or even on my other one... what does the red w/ green stripe do? Could I need a clock specific to an 86 GL? Link to comment Share on other sites More sharing options...
AKghandi Posted May 11, 2012 Share Posted May 11, 2012 Trip computer perhaps? Link to comment Share on other sites More sharing options...
Stubies Subie Posted May 11, 2012 Share Posted May 11, 2012 I soldered the resisters on both clocks, the second one is the old on out of my car, I thinking I got the iron to hot and cooked the resister. we can get another clock over the weekend and try it again the first clock I did, it worked perfect, then I worked on to more clocks, and neither one of them will work at all now. oops Link to comment Share on other sites More sharing options...
92_rugby_subie Posted May 11, 2012 Author Share Posted May 11, 2012 Trip computer perhaps? I considered this, since as a GL, it was an option you could get.... I saw a 85 DL with the trip computer, I almost got mad... I was like WTF is mine in my GL haha Link to comment Share on other sites More sharing options...
92_rugby_subie Posted May 11, 2012 Author Share Posted May 11, 2012 I soldered the resisters on both clocks, the second one is the old on out of my car, I thinking I got the iron to hot and cooked the resister. we can get another clock over the weekend and try it again the first clock I did, it worked perfect, then I worked on to more clocks, and neither one of them will work at all now. oops We have to find some good deals... cuz now I wanna do more to the car before WCSS Link to comment Share on other sites More sharing options...
92_rugby_subie Posted May 11, 2012 Author Share Posted May 11, 2012 Idea. Someone should take these apart (more tech savy than I) and see if we can change the color of the time... to red, or yellow or something. Link to comment Share on other sites More sharing options...
AKghandi Posted May 11, 2012 Share Posted May 11, 2012 you could steal my Ipod idea. check my thread i got better pics its very simple, the hardest part was pulling the wires through the dash without ripping anything. Link to comment Share on other sites More sharing options...
eulogious Posted May 11, 2012 Share Posted May 11, 2012 I soldered the resisters on both clocks, the second one is the old on out of my car, I thinking I got the iron to hot and cooked the resister. we can get another clock over the weekend and try it again the first clock I did, it worked perfect, then I worked on to more clocks, and neither one of them will work at all now. oops Just test the resistor, I doubt you fried it. It takes a lot of heat to really destroy a resistor. The biggest thing with the clocks is to clean up the dirty, old solder that shrunk. I didn't just heat up the existing solder that was there, I added more to it to fill in any gaps that were created from the solder shrinking, and from some of the cold solder joints from the factory... I fixed 2 clocks up no issues using this method... HTH Link to comment Share on other sites More sharing options...
