Horrible miss on 89 Sub GL
Any help you can offer is greatly appreciated.
I have a horrible miss & chugging on my EA82 89 Sub, 250K miles, it will sometime clear up & run like a champ for a day, or a couple of hours, but then this miss comes back to haunt me. It does not miss in the driveway, under any rpms, just under load, when driving at about 1500 - 3000 rpms.
I have changed all of the below:
spark plugs
spark plug wires
rotor
cap
fuel injector (only the injector, not the whole unit)
fuel filter
air filter
coil
It seemed to ok for about a week after I changed the fuel injector, but now is hit & miss. Any other ideas? I am ready give up & park it.:banghead:
Edited by DrFrankenSoob
Mass air flow sensor its the sensor on the airbox. If you unplug it it will go into a default setting so if its bad the miss will dissapear if it isnt it wont
When you unplug it the check engine light will come on.
