Suba_GL_87 Posted May 11, 2012 Share Posted May 11, 2012 1993 EA82 Loyal 4wd wagon; i was overhaul ea82 and repair gasket kits. new clutch kits. also i was replaced new timing belts kit. i did perfectly for timing belt for aliment and i did check rock arm and valve is good. I've been does timing belt for many times and mostly make it. problem is... when i was assembly ea82 and try to starter and still running but try to fire up some how like a *BANG* out of the carb. i was thought timing belt went bad aliment but Ive been 5 times and didn't start it. BANG* check out photo if it's right of aliment. IF so, i dont know what is for...it's mow lawn's engine to me...nonsense. Link to comment Share on other sites More sharing options...
stealth Posted May 11, 2012 Share Posted May 11, 2012 Could be the distributer not in the right place or leads? Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted May 14, 2012 Author Share Posted May 14, 2012 well, i did pull out and put into. still no good. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 14, 2012 Share Posted May 14, 2012 Suba_GL_87 said: 1993 EA82 ... try to fire up some how like a *BANG* out of the carb... A 1993 EA82 with Carb in USA is Rare... Could I Ask if you Swapped some parts from an Old Engine? My EA82 Carb was doing the Same Long Years Ago... and the issue was caused by the Carb itself, that's Why I Swapped a Weber there. Maybe your engine's Carb is Dirty... Was it Running well Before the Timing Belt service? Kind Regards. Link to comment Share on other sites More sharing options...
MilesFox Posted May 15, 2012 Share Posted May 15, 2012 check that the spark plug wires are not reversed between 2 and 4 or 1 and 2. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted May 16, 2012 Author Share Posted May 16, 2012 ive been cleaning carb and rebuilding too. yea, ive been try remove the spark pulg and its was sparking too. 1 3 4 2 Link to comment Share on other sites More sharing options...
rdweninger Posted May 16, 2012 Share Posted May 16, 2012 It is 1-3-2-4 Not 1-3-4-2 as you posted. Also it is counter-clockwise. With #1 being closest to the firewall. Hope this helps. Ron W. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted May 17, 2012 Author Share Posted May 17, 2012 ya, i understand it. my mistake. whats if it's does not work... should i take video for redo timing belt process to starting fire? if so ill installed on youtube, if you see when im mistake. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted May 17, 2012 Author Share Posted May 17, 2012 i smelll gas the carb and see the gas on it...its wont fire out. Loyale 2.7 Turbo said: A 1993 EA82 with Carb in USA is Rare... Could I Ask if you Swapped some parts from an Old Engine? My EA82 Carb was doing the Same Long Years Ago... and the issue was caused by the Carb itself, that's Why I Swapped a Weber there. Maybe your engine's Carb is Dirty... Was it Running well Before the Timing Belt service? Kind Regards. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted May 27, 2012 Author Share Posted May 27, 2012 it's answer. THANK MILESFOX, BTW. Link to comment Share on other sites More sharing options...
