Stuck Brat cylinder 1979
On the bottom left side of the housing there is a pin that holds the cylinder in place. Its small and hard to find but it is there.
If you drill a small hole next to the pin you can use a pick pull it out. Once the pin is out the whole cylinder can be removed from the housing and then take it to a locksmith. Tumblers are probably shot.
I did this with the housing removed from the column but I can't think of a reason why it couldn't be done with it still installed.
