D3F0 Posted January 25, 2016 Share Posted January 25, 2016 (edited) Part# 070430BP http://m.oreillyauto.com/mt/www.oreillyauto.com/site/c/detail/DORN/070430BP.oap?ck=Search_N1163_-1_-1&pt=N1163&ppt=C0248 This unions needs3/16 Inch Tube x 3/8-24 Male fittings. Short or long For example something like this below http://www.oreillyauto.com/site/c/detail/EDE0/121030/N1164.oap?ck=Search_N1164_-1_-1&categoryRedirect=N1164&pt=N1164&ppt=C0248 I fully understand about the daily driver. Also I might keep the mechanical brake there too because I am redoing the system into a two channel system front and rear. It would be nice in an event of a failure for the car to be able to still always have at least front brakes. Its gonna look wacky with two e brake levels. But also for inspection and safety it is probably worth it. Edited January 25, 2016 by D3F0 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 25, 2016 Share Posted January 25, 2016 Thank you for the ideas and part numbers. The "T" looks like it has a straight pass only, no seats at all? ... Its gonna look wacky with two e brake levels ... Long ago I shared my information in a Writeup regarding how to install a Rear parking brake on the third gen Leone (EA82 or Loyale) models, on which I stated on the last paragraphs, that having two levers, one for the Front parking Brakes, and another for the Rear parking Brakes, is like having a poor man's differential Lock on handy, ideal for wheeling offroading. Here is the Writeup, in case you want to see Photos and read further information on the subject: ~► http://www.ultimatesubaru.org/forum/topic/129779-the-definitive-rear-e-brake-retrofit-solution/ Kind Regards. Quote Link to comment Share on other sites More sharing options...
D3F0 Posted January 25, 2016 Share Posted January 25, 2016 What do you mean no seats? Also yes I already looked at that thread I thought it was pretty cool. 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 25, 2016 Share Posted January 25, 2016 ... I already looked at that thread I thought it was pretty cool. Thank you! What do you mean no seats? ... Some fittings for brake piping, have Bubble seat, others have Flared Seat, and others have inverted flare seat. This is an Example of the Fittings and their appropriate Seats, take from another automotive Forum where also I post: So, with that "T" I will need to obtain a small portion of Brake line pipe, and some Fittings like this ones: So, I'll need to know which kind of Seats has the "T" to receive the Fittings. Kind Regards. Quote Link to comment Share on other sites More sharing options...
DaveT Posted January 25, 2016 Share Posted January 25, 2016 I would use inverted flare fittings, just like the others on the car Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 25, 2016 Share Posted January 25, 2016 I would use inverted flare fittings, just like the others on the car Yes, that's exactly what I want to use, otherwise I will need to obtain some adapters, and I really dislike to use Adapters, except on emergency cases, or for short time until finding the proper part. I really liked this design better: But I never found out which style of seat does it have. Also, a used part from another car might be a direct replacement: long ago I readed here on the forums, that certain Toyotas from the 1980's and 1990's decades (Hi-Lux 22R Pick Up) had a "T" with a longer part that is a direct fit, even with the proper seats; but I never obtained further information about that... I hope that someone here will know and enlighten our path. Kind Regards. Quote Link to comment Share on other sites More sharing options...
D3F0 Posted January 26, 2016 Share Posted January 26, 2016 (edited) It uses an inverted(convex) flare and seat is outward. The fitting I linked is the correct one for the T I linked. Its not a bubble flare for the inward one you showed. Its a double inverted. To make this flare you use the flare tool twice. This flare works perfect they are all the same design on the inside Once with flare fitting on and once with it off directly against the flared end to flare the inside so it will pull itself shut. The end result looks like this Its called a double inverted flare. The T uses 3/16 Inch Tube x 3/8-24 Male fittings. Short or long http://www.oreillyauto.com/site/c/detail/EDE0/121030/N1164.oap?ck=Search_N1164_-1_-1&categoryRedirect=N1164&pt=N1164&ppt=C0248 See that is the exact one I used on this line It screws tight and locks in place no problem. Just gotta really tighten these things. Edited January 26, 2016 by D3F0 Quote Link to comment Share on other sites More sharing options...
DaveT Posted January 26, 2016 Share Posted January 26, 2016 +1 F3F0. Best to use a flare nut wrench on them also. Quote Link to comment Share on other sites More sharing options...
