tracedog67 Posted March 26, 2004 Share Posted March 26, 2004 Fellers, I was about to top off the tranny fluid in my '97 OBW Limited 5 speed when the manual says not to mix the gear oils. If i were to just drain the fluid and add new how much would she hold and what type of gear oil should I use? the car has 217k miles on the original tranny and I bought it with 182k miles and I have yet to change it. thanks tdog Link to comment Share on other sites More sharing options...
Soup Posted March 26, 2004 Share Posted March 26, 2004 The Service Manual calls for 75w-90, or 80w-90, If you don't operate your car in low temps, I would use 80w-90, as the 75 is more expensive, and part synthetic. The trans capacity is 3.5 L, or 3.7 us qts. Dan Link to comment Share on other sites More sharing options...
99obw Posted March 26, 2004 Share Posted March 26, 2004 Don't put it all in at first. Put 3 or so quarts in and then fill it up the rest of the way using the dipstick. It is easy to get too much in there. Link to comment Share on other sites More sharing options...
