May 15, 201213 yr The Justy uses a plastic screw to install the inside review mirror, and guess what I broke. Anychance someone has a closet full of these things about
May 16, 201213 yr The Justy uses a plastic screw to install the inside review mirror, and guess what I broke. Anychance someone has a closet full of these things about Try a local hobby shop, they have plastic screws that might fit
May 16, 201213 yr I had the same Problem long Years ago and my Solution was to take out the Screw's thread and search for a Nut that has the same Measurement and Pitch, then I Found a Metallic screw (Inox) and used it... no problem. You only need to be Careful to not over tight it in order to avoid milling the Plastic thread. Kind Regards.
