89ChevondaSI Posted May 16, 2012 Share Posted May 16, 2012 more to come eventually. but finally got my rear OB trailing arm brackets on. Before: After: Link to comment Share on other sites More sharing options...
Uberoo Posted May 16, 2012 Share Posted May 16, 2012 much mo' better! Link to comment Share on other sites More sharing options...
AdventureSubaru Posted May 16, 2012 Share Posted May 16, 2012 What sort of ground clearance are you getting now? Thing looks pretty good! Is there a mod list somewhere? Link to comment Share on other sites More sharing options...
987687 Posted May 16, 2012 Share Posted May 16, 2012 That's quite the beast! I love it! Link to comment Share on other sites More sharing options...
maozebong Posted May 17, 2012 Share Posted May 17, 2012 get a flapper or a turndown angled horizontally so you don't get water in your exhaust already! otherwise, nice work. Link to comment Share on other sites More sharing options...
89ChevondaSI Posted May 21, 2012 Author Share Posted May 21, 2012 Iv got a tractor flap I put on when it rains. But just got 1/4" aluminum Plate for my front bumper. Link to comment Share on other sites More sharing options...
89ChevondaSI Posted May 21, 2012 Author Share Posted May 21, 2012 What sort of ground clearance are you getting now? Thing looks pretty good! Is there a mod list somewhere? Iv got 10 1/2" to the oil pan and 11 3/4" to the rear diff. suspension mod list; OB KYB struts all around, 1" subtle solutions lift spacers, forester Rear springs, OB rear trailing arm brackets, MB motoring wheels. 15x6.5 with +38 offset Hankook Dynapro MT's LT215/75R15's performance mods; Rebuilt 2.5L DOHC, milled heads to bump up compression, valve job, UEl header, Ported intake Manifold and Throttle Body, custom exhaust, Snorkel, K&N filter. then lots of other random stuff. Link to comment Share on other sites More sharing options...
el_freddo Posted May 26, 2012 Share Posted May 26, 2012 Iv got a tractor flap I put on when it rains. But just got 1/4" aluminum Plate for my front bumper. Are you going to put some slots or holes in the plate to allow some air flow into the radiator, or you're getting enough air in there even with the plate in place? Cheers Bennie Link to comment Share on other sites More sharing options...
89ChevondaSI Posted May 26, 2012 Author Share Posted May 26, 2012 I'm actually getting plenty to keep it cool. but i have a friend that does CNC machining. I was thinking about getting the Subaru badge cut out. Link to comment Share on other sites More sharing options...
Tosh Posted June 12, 2012 Share Posted June 12, 2012 you got any pictures of how your snorkel is hooked up in the engine bay? I've been thinking about adding one to my wagon and am trying to figure out the best route. Link to comment Share on other sites More sharing options...
89ChevondaSI Posted June 14, 2012 Author Share Posted June 14, 2012 I can post some up later. Link to comment Share on other sites More sharing options...
Tosh Posted June 15, 2012 Share Posted June 15, 2012 cool thanks! I've got a 01 EJ22, but no intake just the airbox with the 90 degree bend towards the front. Link to comment Share on other sites More sharing options...
89ChevondaSI Posted January 1, 2013 Author Share Posted January 1, 2013 weeelll. long time no update. blew the engine back in december and picked up another subie. an '05 RS for my d.d. so now it's saving time so I can swap an EG33 into this beast. Link to comment Share on other sites More sharing options...
torxxx Posted January 3, 2013 Share Posted January 3, 2013 keep in touch with me on the EG33 swap. My SVX body/chassis is getting worn out to the point of its a money pit so I've been comtemplating dumping the motor into my lifted OB My biggest hurdle is the wiring harness merge. I have a spare 92 (04/91 mfg date) SVX at the shop with the engine already pulled so as soon as we see some temps above 15F I'll start pulling the harness. Did you notice any powerband shift running the UEL header over stock exhaust? I've been close to buying a set of headers from subie101, but if theres not a noticeable difference the $$$ could go to a different part of the car (like a LSD front carrier) Snorkel setup, are you running a pre-filter at the end of the snorkel or just 1 air filter before the MAF? Sorry bout all the questions, just not too many Gen1 outbacks/Gen2 Legos that are lifted and actively post on the board Link to comment Share on other sites More sharing options...
wagonryan Posted January 4, 2013 Share Posted January 4, 2013 ^^^ I have a UEL header on my 2.2 obs. I didn't notice any big changes in throttle response, but it feels faster haha. Its definitely cool to have the subie rumble. I think 300 or whatever they're running is a good price. keep it up keaton! Link to comment Share on other sites More sharing options...
AdventureSubaru Posted January 4, 2013 Share Posted January 4, 2013 Good to see this is still around. I was thinking you had sold it. Thing is going to be a beast with the EG33. No small task getting one in there. Looking forward to seeing the progress. Also nice to see that there are still some other lifted subes in the area. Link to comment Share on other sites More sharing options...
89ChevondaSI Posted January 9, 2013 Author Share Posted January 9, 2013 alright. so as for the UEl i might have lost a tiny bit of low end torque but that's it. Idk about you guys but I got mine for $150ish off ebay new, sure its a replica, but I sure as hell aint gunna spend $300 on a header for an n/a. Then as for the snorkel it runs into the stock airbox, quick hp is to swap the tube from the filter box to the TB off a 2.2. they dont have that stupid box. just that and new breather hoses is all that entails. easy and cheap. Then to prevent anything big from coming in the end I actually have a shower drain insert glued in to keep stuff out. Link to comment Share on other sites More sharing options...
86BRATMAN Posted January 10, 2013 Share Posted January 10, 2013 alright. so as for the UEl i might have lost a tiny bit of low end torque but that's it. Idk about you guys but I got mine for $150ish off ebay new, sure its a replica, but I sure as hell aint gunna spend $300 on a header for an n/a. Then as for the snorkel it runs into the stock airbox, quick hp is to swap the tube from the filter box to the TB off a 2.2. they dont have that stupid box. just that and new breather hoses is all that entails. easy and cheap. Then to prevent anything big from coming in the end I actually have a shower drain insert glued in to keep stuff out. just to expand on the intake tube, it's gotta be a pre 97 ej22, mine had the big stupid box till the other evening love this car btw, one of a few that made me spend the time finding the struts and springs to get mine in the air Link to comment Share on other sites More sharing options...
89ChevondaSI Posted January 10, 2013 Author Share Posted January 10, 2013 Thanks. iv always kinda been the loser. so knowing that iv inspired a couple people makes it that much better. Link to comment Share on other sites More sharing options...
89ChevondaSI Posted June 23, 2013 Author Share Posted June 23, 2013 No....this car isn't sold. but iv been building and swapping so many cars on the side lately I haven't hardly started on the harness merge... Link to comment Share on other sites More sharing options...
Uberoo Posted June 25, 2013 Share Posted June 25, 2013 Sad Face Link to comment Share on other sites More sharing options...
