shortysayhi Posted May 17, 2012 Share Posted May 17, 2012 (edited) So I've been looking all over and can't seem to find one. I need this diagram to be able to splice my harness into my brat. If someone has one please send me it. Shortysayhi@yahoo.com Edited May 17, 2012 by shortysayhi Link to comment Share on other sites More sharing options...
JT95 Posted May 17, 2012 Share Posted May 17, 2012 Phase I or Phase II? I could use one for a PHASE II... Link to comment Share on other sites More sharing options...
shortysayhi Posted May 17, 2012 Author Share Posted May 17, 2012 JT95 said: Phase I or Phase II? I could use one for a PHASE II... ej22t is phase 1 ej22G is phase 2 Or so says wikipedia. I need phase 1 according to wikipedia. Link to comment Share on other sites More sharing options...
Prwa101 Posted May 17, 2012 Share Posted May 17, 2012 check the diagrams i sent you, they may be mostly the same. compare your ecu plugs, to the two files at the bottem of this, http://offroadingsubarus.com/downloads/EA2EJ.pdf if the ecu wires match up with color and place. itll work better than nothing. let me know how it goes. you should take a picture of the ecu plugs and post it on here. -Prwa Link to comment Share on other sites More sharing options...
shortysayhi Posted May 17, 2012 Author Share Posted May 17, 2012 This pic? Link to comment Share on other sites More sharing options...
Prwa101 Posted May 17, 2012 Share Posted May 17, 2012 hey in the wirte up, diagrams at the bottom, it tells you what turbo wires are there. F47 pin 20 "pressure exchange solenoid valve" F47 is the largest plug on there Link to comment Share on other sites More sharing options...
Prwa101 Posted May 17, 2012 Share Posted May 17, 2012 http://www.numbchuxconversions.com/Files/FSMs/92%20Legacy%20Engine%20Wiring.pdf almost all of these apply to your harness what year is this harness?? take a picure of the ecu plug it selflooking into the wires Link to comment Share on other sites More sharing options...
Prwa101 Posted May 17, 2012 Share Posted May 17, 2012 http://www.numbchuxconversions.com/Files/FSMs/1992_Legacy_ECU_I-O.pdf all the ones that say turbo apply to you (mayby others). you can look at the pin number on the file and itll show you what wires it is in the pin, fallow it back through the harness and itll lead you to a plug LABLE IT Link to comment Share on other sites More sharing options...
shortysayhi Posted May 17, 2012 Author Share Posted May 17, 2012 Its out of a 94 ej22t Wagon. Link to comment Share on other sites More sharing options...
wtdash Posted June 9, 2012 Share Posted June 9, 2012 This will help w/the pinout on the ECU plugs - HERE. GL, Td Link to comment Share on other sites More sharing options...
