adjusting rear brakes drum 95 wagon
sounds like something rubbing just a quick rubbing , when i put newer hub, bearing knuckle ,parking brake , brake line , i did not adjust anything , used the shoes that came with the whole unit , the other side is good ,
If it goes up or down with speed,may be just the drum rubbing on the backing plate,or a shoe doing the same thing.
If a shoe, you'll have to remove drum and adjust parking pawl until it stops. ( ie, so that when the brakes are released they'll retract far enough)
O.
