backspacing on an imp
wagonryan
I'm looking at diamond racing pro series in the 15"X7" and I'm not sure which backspacing to get. I wanna run 215/75/15 general grabbers and they will definitely not fit with my current backspacing. I have about a centimeter from my 205/55/16's to the strut so I need the backspacing to stick the tire out about an inch or so to clear the strut.
anyone use these on imps?
well I was rubbing on my stock wheels with bigger tires on the struts.
now I have 215/75's and a better offset.
if ur going with the 15x7 go with a 4" or 5" backspacing. that way you won't destroy WB's and other stuff but still have a nice look.:banana:
Thanks a lot man, maybe I should just ask you these things on FB haha
gonna go with a 4" backspacing then cause they don't have an option for 5".
do you know what the backspacing for stock subaru alloys is? I could measure but i'm not at home atm
lets see....
5.5in usually a +45 offset for stock..
so thats
5.5inx25.4 to convert to mm. which is 139.7 so 140 for esey math
then half of that is 70 for the measurement then plus 45 = 115
then 115/25.4 to get back to inches = 4.53" of stock back spacing. :banana:
so the diamond racing ones would give you an extra 1/2" :brow:
