xbeerd Posted June 9, 2012 Author Share Posted June 9, 2012 cool, i dont think i'll have time to swap an axle today, so i would love to hear if that fixed it on yours Link to comment Share on other sites More sharing options...
TheLoyale Posted June 9, 2012 Share Posted June 9, 2012 Did you figure it out? Link to comment Share on other sites More sharing options...
Txakura Posted June 10, 2012 Share Posted June 10, 2012 One thing about the USMB... I can read about the problems I have, or the problems I'm going to have. Pure evil, I hope you find this. Link to comment Share on other sites More sharing options...
xbeerd Posted June 10, 2012 Author Share Posted June 10, 2012 well, i did 2 things yesterday, i swapped the axle out for one with an axle from Tom. and i tighted down the trans mount bolt just a tad, but the engine crossmember was snug as can be and not moving at all. so i would tend to believe that the axle was the culprit, the clunk is not 100% gone, HOWEVER, it happens very rarely. and i DID notice now that my other side has a split wide open cv boot too. (damn it!) Link to comment Share on other sites More sharing options...
maozebong Posted June 10, 2012 Share Posted June 10, 2012 i used to have the same clunk, it would actually clunk around corners like a cv, but once i jacked the car up, the wheel bearing had a ton of play. you can check by grabbing at 12 o'clock and 6 o'clock, and shake the wheel back and forth. also, at low speed it would clunk like a tie rod when i shake the steering wheel side to side. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 10, 2012 Share Posted June 10, 2012 Just sounds like the solid "clack" I used to get out of my old ranger when I put it in drive. Only did it one in ten times, but had to do with driveshaft position more than anything else I could figure. Never shook or wobbled at speed. Replaced the front u joint and it never do it again. Inner cv joints can do this when the outer housing is worn. Grooves wear into the housing where the bearing normally rides. After a while the groove gets so deep the bearing starts to hang on it and will bind the axle. When it lets loose you get a big pop. Got 4wd? Remove the front axles and go for a spin? Alot of work but it will rule out axles if they aren't the cause. Link to comment Share on other sites More sharing options...
xbeerd Posted June 11, 2012 Author Share Posted June 11, 2012 Fairtax4me said: Just sounds like the solid "clack" I used to get out of my old ranger when I put it in drive. Only did it one in ten times, but had to do with driveshaft position more than anything else I could figure. Never shook or wobbled at speed. Replaced the front u joint and it never do it again. Inner cv joints can do this when the outer housing is worn. Grooves wear into the housing where the bearing normally rides. After a while the groove gets so deep the bearing starts to hang on it and will bind the axle. When it lets loose you get a big pop. Got 4wd? Remove the front axles and go for a spin? Alot of work but it will rule out axles if they aren't the cause. iwonder if it was the inner then, the axle did look pretty damn old. possibly original axle, but it was hard to tell as it was all skanky. Link to comment Share on other sites More sharing options...
