Lightening a clutch
the slave cylinder would only work on the newer cars with a hydro clutch, there really isn't much you could do, except possibly extending your pedal a few inches, that would multiply the torque from your foot. with the cable theres not too much you and do.
ya, or take the cable off and lube the rust out of it. my 89 is very heavy, but my 86 with new stuff on it is pretty light.
but, if you have a hill holder, and never use it. you can take that off and put a light carb return spring in its place, that will make it lighter feeling.
to lighten the pedal weight, drill holes in it
to reduce the force, you "could" 1. add a pulley system for mechanical advantage, or 2. use a different clutch setup that changes the configuration of springs involving angles and rates
to lighten the rotating mass of the clutch, you "could" use a ceramic 3 or 4 pad disc
I don't use any things that you speak of, I just "tweak" cars and computers
I know what I talk about, and have a hi degree of respect and knowledge on the board, and in real life
there's 4 subarus on this road where I live, and one is mine
no smoke, drink, whatever
:madder: :argue: :madder: :argue: :madder: :argue: :madder: :argue: :madder: :argue:
I started this post after archemitis, and finished after bushbasher, not seeing that bushbasher had posted
I'd like to see a pulley clutch system lol
Hes not on crack he's just creative.
I dont get the adding ceramic disc part though
I'm creative combining necessity, opportunity, and experinence
ceramic disc is something I have thought of a long time
http://www.roadranger.com/products/clutch/clutch_solo_md.htm shows 3 pad ceramic solo
http://www.roadranger.com/products/clutch/clutch_ep2000_epplus.htm is the ez pedal
http://www.roadranger.com/products/clutch/clutch_solo_hd.htm shows solo 6 pad ceramic
http://www.roadranger.com/products/clutch/clutch_solo_xl1552.htm shows the xl with many good pics
from what I know, roadranger "solo" clutch kit is the way to go if they make one for the car, no idea because most are for the big otr trucks :eek:
Usually remanufactured is NOT worth the trouble
you want a ceramic disc with dampening springs
xl is usually NOT worth the extra money you spend for the FEW cents you save in grease
ez pedal was designed to reduce the effort to accommodate the women drivers, and the weak ones by messing with the spring rates and angles
a solo clutch can "break" by not self adjusting, but can be easily fixed with wd40 and the special tool
