ecu clicking
Long story short I pulled engine and changed the clutch. Now I got check engine light and an egr code. The car now stumbles and I hear cycling sound in the ecu. Any ideas? It is a 94 Loyale wagon. Thanks
Probably not the ECU, more likely a relay clicking. The ignition and fuel pump relays are only a few inches from the ECU. That is a normal sound for a relay, NOT a normal sound for the ECU. The ECU has no moving parts to click--if it IS clicking, it probably isn't working.
The test connectors are unpluged. The clicking is from relay just above the ecu. What would this relay control? :banghead:The car starts and idles fine just stumbles under load. 2-3 grand on tach. Got new plugs and fuel filter. Don't have a ground to intake on passenger side. Going to check grounds and try coding again tomorrow.
Relays normally click when they first power up. Are you trying to say they click continuously? They should just click a couple times when you start the car, and the fuel pump relay may click occasionally as it powers up and down while you drive, though not continuously.
