SubiDemon Posted May 24, 2012 Share Posted May 24, 2012 Hey guys, hopefully you can point me in the right direction. My car is a 1990 Legacy wagon with 5mt I pulled into a parking lot yesterday and when I tried to downshift into 2nd, it wasn't there. There is no grinding, or noises of any kind. It's like 2nd gear just isn't an option in the shift pattern anymore. Is this a shifter or transmission problem? Link to comment Share on other sites More sharing options...
Robert Harik Posted May 24, 2012 Share Posted May 24, 2012 Will it shift into second with the engine off? Link to comment Share on other sites More sharing options...
rallynutdon Posted May 24, 2012 Share Posted May 24, 2012 It ccould be a broken shifter fork. I had 2 where they broke for 1st gear from being forced in to 1st (both rallycross/racing situations). Link to comment Share on other sites More sharing options...
SubiDemon Posted May 25, 2012 Author Share Posted May 25, 2012 on my way home from school today I tried pushing the shifter as far to the left as I could repeatedly and then tried pulling it down into second and it worked! 3rd gear no longer grinds either. But, by the time I got home it was grinding going into 2nd. Is there a way to adjust the linkage? When I was inspecting it yesterday I saw it was a single rod that rotates for the left right motion at the stick and goes forward and back for the same direction at the stick. Link to comment Share on other sites More sharing options...
rallynutdon Posted May 25, 2012 Share Posted May 25, 2012 Is your clutch adjusted properly? No way to "adjust" shift linkage. Link to comment Share on other sites More sharing options...
