Sabaroo Posted May 27, 2012 Share Posted May 27, 2012 So my Impreza is finally running, but when I plug my OBD2 in & clear the error, start the car up again runs fantastic then the error pops up again after about 20 sec of running then it runs like poop. I have adjusted the throttle cable and took off the throttle body and cleaned it up good using cleaner (looks new). Any Ideas? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 27, 2012 Share Posted May 27, 2012 You need a new Idle Air Control (IAC) valve. GD Link to comment Share on other sites More sharing options...
Sabaroo Posted May 27, 2012 Author Share Posted May 27, 2012 thansk, yeah I figured so, anyone know where to order one on the cheap side? Link to comment Share on other sites More sharing options...
ocei77 Posted May 27, 2012 Share Posted May 27, 2012 GeneralDisorder said: You need a new Idle Air Control (IAC) valve.GD Not necessarily. Try a thorough cleaning first. Remove from TB and separate plastic housing. The screws are soft and from an earlier post I took advice and replaced screws with cap head screws. 8mm for body and 4mm for housing. The wheel that opens and closes is magnetically driven and sticks from carbon buildup. Clean and make sure the wheel turns freely. Clear code and reinstall. Should resolve the issue. If not, junkyard, after verifying which you have. there are at least 3 types. They are not cheap otherwise. O. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 28, 2012 Share Posted May 28, 2012 I've tried cleaning them many times and it never really helps. Replace it. GD Link to comment Share on other sites More sharing options...
Sabaroo Posted May 28, 2012 Author Share Posted May 28, 2012 I have already taken her all apart & cleaned I probably going to opt for a new one and hopefully Shawn's got one. Link to comment Share on other sites More sharing options...
ferret Posted May 28, 2012 Share Posted May 28, 2012 They are expensive. Even the part itself on EBAY. I usually look on Ebay for an entire Throttle Body with the IACV on it. You can usually get one cheaper than the individual part. http://www.ebay.com/itm/1999-1998-97-98-99-subaru-forester-impreza-2-5-throttle-body-/260900398761?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cbee026a9&vxp=mtr http://www.ebay.com/itm/00-01-SUBARU-LEGACY-OUTBACK-2-5L-4CYL-THROTTLE-BODY-THROTTLE-VALVE-ASSY-/120895629051?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru&hash=item1c25f0e6fb&vxp=mtr Let me ask ...... is this a 5 speed ? If it is, the Idle Switch on the transmission can be causing this also. I usually see this when someone is driving/moving. It tells the ECU when you are in gear, This and speedometer pulses tell the ECU you are moving, so the ECU does NOT control the idle. When the switch goes BAD, the ECU sees the car moving, but NOT IN GEAR, like coasting in neutral. So the ECU TRIES to control the idle, but since you ARE in gear, it can not, so it sets P1507. Link to comment Share on other sites More sharing options...
Sabaroo Posted May 28, 2012 Author Share Posted May 28, 2012 It is a 5 speed it's stiil siting on jacks & hasnt been in gear while running. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 28, 2012 Share Posted May 28, 2012 Your valve is likely fine. All you really need is the duty solenoid on top of the valve. I've had several instances of this situation after engine swaps. Every time I've put the solenoid from the old engine on the new valve its worked just fine. GD Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 29, 2012 Share Posted May 29, 2012 Is this on the 2000 model in your profile? I believe that one should have the cone type valve that screws to the side of the TB. Those are way expensive and hard to find in junkyards. I had to replace one and ended up getting it off eBay for $75. Not as good a price as a junkyard part but the seller warranted it for 30 days. Has been working for a few months now with no problems but I understand this style IACV fails often. Link to comment Share on other sites More sharing options...
Sabaroo Posted May 29, 2012 Author Share Posted May 29, 2012 well I have to get one , rather have a new one. Link to comment Share on other sites More sharing options...
Sabaroo Posted June 24, 2012 Author Share Posted June 24, 2012 Put on today & it's purring like a Japanese Kitten Link to comment Share on other sites More sharing options...
Ricearu Posted June 25, 2012 Share Posted June 25, 2012 it has tentacles? Glad it's running good! Link to comment Share on other sites More sharing options...
