GTlegs Posted May 28, 2012 Share Posted May 28, 2012 Hi All, I need to remove my EA82 from a GL. It has an auto box. The question is, besides the engine to diff bolts, is there any other bolts I need to remove (eg crank to torque converter, etc)? Thanks Link to comment Share on other sites More sharing options...
Prwa101 Posted May 28, 2012 Share Posted May 28, 2012 dont forget about the 4 motor mount bolts. Link to comment Share on other sites More sharing options...
man on the moon Posted May 28, 2012 Share Posted May 28, 2012 Exhaust studs! 4 studs w/nuts. Link to comment Share on other sites More sharing options...
tractor pole Posted May 28, 2012 Share Posted May 28, 2012 Search for Miles Fox's YouTube he has a great step by step video series. Ben Link to comment Share on other sites More sharing options...
kabarakh Posted May 28, 2012 Share Posted May 28, 2012 Search for Miles Fox's YouTube he has a great step by step video series. Ben Ditto to the above. Videos are titled "the art of subaru maintenance" it's a stepp by step video pictoral that will answer all your questions. Link to comment Share on other sites More sharing options...
Gloyale Posted May 29, 2012 Share Posted May 29, 2012 The question is, besides the engine to diff bolts, is there any other bolts I need to remove (eg crank to torque converter, etc)? Thanks yes, 4 bolts holding Torque converter to the flexplate. 12mm head, (m8x1.25) access through timing hole in bellhousing. If the intake is coming off anyhow, do it first, it will make accessing the blots easier. Link to comment Share on other sites More sharing options...
kayakertom Posted May 31, 2012 Share Posted May 31, 2012 Don't forget to drain your trans fluid first. Link to comment Share on other sites More sharing options...
