nncoolg Posted May 29, 2012 Share Posted May 29, 2012 Just wondering if anyone has had 15" 505 alloy peugeot wheels on a 2wd XT? Im asking because I had one of the OE wheels off mine today so I sat one of the 15" peugeot wheels I have on to see how they look. They look good, but I am concerned about the offset. The measured difference of wheel mounting surface to outside tyre wall between the two types of wheels is around 35mm, 35mm more sticky-outy on the peugeots, which I reckon will foul the guards. The reason I ask about 2wd XT's is that I reckon if they go on them, they will go on the 4wd's and mine which is somewhere in the middle of the 2 ride heights. Were talking 195-50/15 tyres here too guys I dont know if the split-spoke and flat-spokes are different, I have the flat spokes. thanks. Link to comment Share on other sites More sharing options...
Gloyale Posted May 29, 2012 Share Posted May 29, 2012 I've got some wider offset rims on my 2wd XT and they fit just fine. As long as the tire is small enough diameter to tuck into the wheel well, it should be fine. Not like a 2wd will see alot of crazy articulation or wheel travel. Link to comment Share on other sites More sharing options...
