Mrs. Robles Posted May 30, 2012 Share Posted May 30, 2012 (edited) Hi guys. A few weeks ago I took my car to get the power steering pump replaced and afterwards, the car would vibrate when stopped at a light or stop sign and while in the drive position. If I switch to neutral, park, or reverse the vibration stops. I have seen threads for this but no final outcome on what the problem was. It is with a friend at a different shop now because I think the first guy I took it to was not being very ethical or honest with me. The shop it is at now is having a tough time figuring out what it is so here I am. Trying to get some ideas on what might be making this happen. So far we know its not any of the mounts. Any help would be appreciated Edit: The vibration is not steady...it starts to vibrate, then stops, then vibrates again...sometimes more than others. Edited May 30, 2012 by Mrs. Robles Link to comment Share on other sites More sharing options...
nipper Posted May 30, 2012 Share Posted May 30, 2012 Have the axles ever been replaced? When was the last time this had a tune-up? What other work has been done in the past Link to comment Share on other sites More sharing options...
Mrs. Robles Posted May 30, 2012 Author Share Posted May 30, 2012 there was something that was recently replaced, I believe it was a joint or something (maybe a mount?) on the front axle that was cracked and that was replaced. I just read somewhere else that it might just need a tune up (has been a long time) so I am going to get that done tomorrow and see if that helps. Thanks for the reply. =) Link to comment Share on other sites More sharing options...
nipper Posted May 30, 2012 Share Posted May 30, 2012 Tune up never a waste of money. I bet you had a cv joint replaced with something that was not a subaru part. Link to comment Share on other sites More sharing options...
Recian Posted May 30, 2012 Share Posted May 30, 2012 Yea that seems to be an issue with automatics. Mine had it too b4 i converted to 5speed. I have a bad axle too. If tune up doesnt fix it id consider getting a set of axles. They usually last alot longer than aftermarket so you should go subaru. Also aftermarkets tend to cause alot of problems from what ive seen Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 30, 2012 Share Posted May 30, 2012 have your shop check the pulleys and tensioner for the serpentine belt. But yeah, many people do report vibration from rebuilt axles. What was wrong with the power steering? Link to comment Share on other sites More sharing options...
skishop69 Posted May 31, 2012 Share Posted May 31, 2012 Guys, hate to knit pick.... "the car would vibrate when stopped at a light or stop sign" Not going to be axles. We just bought a Baja and it does the same thing. I'm going to do a tune and injector service. Could be a belt and tensioner issue, but I doubt it. Those are almost always constant. Could just be a coincidence it started after the repair but there are some scheisters out there. Link to comment Share on other sites More sharing options...
nipper Posted May 31, 2012 Share Posted May 31, 2012 skishop69 said: Guys, hate to knit pick.... "the car would vibrate when stopped at a light or stop sign" Not going to be axles. We just bought a Baja and it does the same thing. I'm going to do a tune and injector service. Could be a belt and tensioner issue, but I doubt it. Those are almost always constant. Could just be a coincidence it started after the repair but there are some scheisters out there. i DID say start with a tuneup. Link to comment Share on other sites More sharing options...
