aircraft engineer Posted May 30, 2012 Share Posted May 30, 2012 The unlock on my alarm button (python) works fine, the alarm sets but the doors won't lock. also when the key is truned on, the doors don't autolock. The KEY locks all the doors (just like it should) Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted May 30, 2012 Share Posted May 30, 2012 check for a bad fuse. Quote Link to comment Share on other sites More sharing options...
crazyman03 Posted May 31, 2012 Share Posted May 31, 2012 do you have a factory auto lock/unlock switch? does it work as it should? depending on who installed the alarm and the model, there might be a fuse between the unlock relay (either IN or external of the python alarm) and the unlock (action) wire. check the wire harness of the alarm for breaks, also check fuses. IF there is a relay, you might check it too if you can. -Justin Quote Link to comment Share on other sites More sharing options...
