tallwelder81 Posted May 31, 2012 Share Posted May 31, 2012 i have my brat mostly lifted. 2 in rear, 2.5 in front. but i cant figure out how the radius rod lift works out? do i need 2 blocks, 1 per side? with 1 bolt per block? cuz that is what i was given with my kit. but it seems like i must need more blocks. can anyone send me a clear pic of that area, on a lifted brat? alos, if i am lifting my front body 2.5 inches, does my steering shaft need extension? or will it work fine stock? pics of front chassis area on lifted brat, please??? the swaybar/radius rod/tranny area. or ANYTHING. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 31, 2012 Share Posted May 31, 2012 Radius rod mounts with 3 blocks, or at least 1 long w/2 holes and 1 short(per side) Steering shaft will definately need lengthed. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted June 1, 2012 Share Posted June 1, 2012 only if your keeping the sway bar.other wise just two. Quote Link to comment Share on other sites More sharing options...
tallwelder81 Posted June 2, 2012 Author Share Posted June 2, 2012 should i NOT keep the sway bar? why wouldnt i want a swaybar? i dont do much crawling. just, you know, 30mph logging road rally. and the occasional curb hop, or 2'x2' ditch crossing. nothing extreme. i do about 90 miles of street driving for every 10 miles of gravel or dirt or mud or snow. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted June 2, 2012 Share Posted June 2, 2012 the sway bar really kills wheel travel,so it will ride rougher on logging trails with it on there. just without the swaybar it will handle like an old truck,with a low center of gravity.try it with and without the swaybar and see what way you like best.The swaybar is always the first thing to go on my subarus. Quote Link to comment Share on other sites More sharing options...
Cyfun Posted July 2, 2012 Share Posted July 2, 2012 You will probably want to ditch the sway bar. I had to remove mine after my 2" lift simply because it didn't line up anymore with the control arms, and would also rub on my tires if I turned to full lock. Quote Link to comment Share on other sites More sharing options...
