Carl B. Posted June 5, 2012 Share Posted June 5, 2012 I started the rear suspension swap from an xt6 into my Loyale wagon today. Does anyone have pics of where and how they mounted the sway bar to the chassis? Link to comment Share on other sites More sharing options...
Subruise Posted June 5, 2012 Share Posted June 5, 2012 you gotta have the brackets on the trailing arms. if you trailing arms dont have em youll have to get creative. Link to comment Share on other sites More sharing options...
Carl B. Posted June 5, 2012 Author Share Posted June 5, 2012 I have the trailing arms with mounts, but I assumed the bar should mount to the chassis similar to the front sway bar, no? Link to comment Share on other sites More sharing options...
Subruise Posted June 5, 2012 Share Posted June 5, 2012 huh, ill have to go look at mine. mine is gl-10 suspension, but should be similar Link to comment Share on other sites More sharing options...
Carl B. Posted June 6, 2012 Author Share Posted June 6, 2012 thanks Subruise, waiting to hear from you. Anyone with an xt6? Maybe you don't mind taking a look under your ride. Link to comment Share on other sites More sharing options...
El Presidente Posted June 6, 2012 Share Posted June 6, 2012 I just pulled a rear sway off a gl-10 turbo at the jy and it didn't attach to the body, just two mounts on each trailing arm. Josh Link to comment Share on other sites More sharing options...
Numbchux Posted June 6, 2012 Share Posted June 6, 2012 I have the trailing arms with mounts, but I assumed the bar should mount to the chassis similar to the front sway bar, no? nope, 2 mounts on each trailing arm. that's it. Link to comment Share on other sites More sharing options...
Carl B. Posted June 7, 2012 Author Share Posted June 7, 2012 thanks, for the info. Got that sway bar installed today. Link to comment Share on other sites More sharing options...
