97 outback
1-3-2-4
I been here all this time and never knew we had a member's ride haha going be awhile to get everything right but I figure I will start off with this..
I was testing out the JDM headlights i used a 3 up rebel 4500K LED's driven at 700 mA using a signal relay in order to get my high brightness when the headlight is on and turn signal is triggered.
I found a resistor which would look good for a parking light brightness, stock RHD projectors were taken out and I put in FX-R projectors in.. I just need the Denso ballast next to finally get everything done.
I'm sure most everyone know I just did the transmission last week while I did that I took the clutch off and inspected it and it looked very good, no hot spots or anything.
In Aug the car is getting painted all black from it's current dark blue/grey color.
  • 1 month later...
Got a bunch of parts coming in.. new front calipers new rotor's for the front and rear.
I did powder coat the rear hats to the same color of my wheels I'm going to put on late this month.
I ordered (finally) a new center pipe since when I took of the stock when doing the transmission it fell apart almost instant because of the rust...
I also ordered some new heater core hoses because the stock one at least one of them I saw spring a pin hole size leak when I went to remove the starter to do the contacts and that's when I spotted.
This is planned for later in the week :cool:
Yesterday I finally passed 300 miles from the tank with a mix of highway/city driving
Edited by 1-3-2-4
yeah it's auto dim I just need to find the right button mount first then I will worry about the temp sensor part.
It's going to help with those people I encounter on the road going to work in the morning with badly aimed headlights.
I forgot to post the video
Finally got around to powder coating the front rotor hats tonight so that's all done.
Edited by 1-3-2-4
My ballasts for the headlights came today :D the perks for working at UPS delivery at 8:30 AM haha.
Don't think I will keep the bulbs I have in it now.. I think the bulb made a bad connection and ended up arcing 23 kV at the ring terminal..
Nevertheless warmup is like 6 seconds I just need to mark and level outside when it stops raining..
A little video tonight!
Calipers are still misplaced so I can't figure out what the bore size is for the calipers in the front for the outback.. I have some brand new calipers I'm going to strip and power coat however the mm number must be a top secret Subaru number ;)
End of the week I have to get the pipe for the exhaust bent into shape, I just now noticed I don't know if I have enough powder to shoot 4 calipers.. or let alone 2.. I don't know if I want to use the HF powder because the UV I hear makes it turn chalky looking after exposed to the sun over some set amount of weeks.
Kinda got a late start today but I took off the 2nd cat and put on the one that's been in the house for over a year.. nothing was wrong with the stock one.. I'm keeping it just incase I don't pass emissions with the 2nd one since it's semi-gutted.
I put on the resonator now so it's a bit better now but the friken exhaust studs.. the bolts I got at the home depot today are too long I think I picked up 30 mm it's just too long.. So unable to put the new gaskets on because that leak is so loud..
Should be doing the dimming rear view mirror today, I ordered a replacement button from the chevy dealer which should of been in Monday however when I called they said they had a computer problem on Friday.
I did a quick test with my retro HID headlights with LED turn signals I have to wrap the wires for the turn signals because I don't want it to rub on any body panels.
btw that bosal pipe was for my 2.2 Legacy wagon but for some reason none of the gaskets really fit it right, being cheap I ended up shaving the whole inside of the gasket so it would fit over the pipe.. and that's a dealer gasket...
So thinking hmm let me try another and sure enough the new gasket same thing.. It's like the pipe is too thick for any donut gasket.
Got the mirror installed today.. tonight I have to work on the headlights I have to see if I can try to get a rough aim inside the house so I can put them on the car tomorrow and do very little aiming to hit my mark of 26 inches @ 25' That puts the top of the headlight beam just about middle ways of a car's trunk.
here is a mirror picture
Yesterday got the rotors in for all 4 and new pads all 4. Put the new headlights in and it's nice to have a good wide view of the road.. While having the car up on all 4 jacks my tires seem a bit unbalanced so I'm getting new tires next month anyways but it was interesting to see the strut top hats jumping up and down.
So also with the headlights I need a Tridon EP34 because I had the hyperflash but now it's back to normal.. I think the Stock Subaru is 60 fps but the new one is 80 fps, so a little faster but still looks normal but I prefer the flash flash anyways.
Now later today I will cut into the body inside to fix that blasted broken nut for the tranny crossmember!
I think I ended up taking it off with the tire still on, I thought it was going to be really hard to get off but it was pretty simple.
Finally got the sub sender out and replaced the nuts that held it down (rusted)
Helping out a friend today :D
  • 4 months later...
lol ^ I haven't still replaced those fuel senders yet.. but in 2 weeks I will but right now time for some tires, we had some sleet on Tuesday and with my tires pretty much bald I had to keep my speed under 45 mph and still you could feel when the car hit the crown in the road it started to slip a bit.
Looking at getting these General Altimax Arctic, also I have to strip the wheels on the car now and powder coat those since they are looking pretty rough now, but since they will be winter wheels it does not need to be anything crazy.
  • 3 weeks later...
arrrgh.. so I ordered the Fuel sender's from subarupartsforyou.com and picked customer pickup.. waited and waited.. so around 4 PM or so I get a email about a tracking number and I'm like WTF? It seems like they got confused and shipped it instead of having me come and pick it up.. Oh well no extra charge but at least I can finally have a working gauge again instead of working when it wants to..
Now I gotta get the winter tires mounted tomorrow and wheels cleaned up then I should be ready for this snow for Friday.
Fuel sender came.. looks like they made a mistake and sent it UPS when I asked for customer pickup.. Oh well no charge.. I never knew this stuff was this color when new...
meanwhile I was running back and forth to get my tires taken off so I could strip and power coat them.. I had planned to do this over early fall but I had other things to take care of.
About 10" or so.. but this one area I went to had drifts up to a foot at least, it was at a school and unplowed and I wanted to see if I could make it.. had to keep your momentum going and I heard them tell me "Oh look he's going to get stuck" I never did but this Nissan SUV did.
haha! Those videos were great. Glad to see I'm not the only one that got out in the white stuff today! Got about a foot down here in Jersey! :) Got pics and video up on my thread too if you wanna check em' out. Not nearly as interesting though, but fun stuff!
