crazyman03 Posted June 8, 2012 Share Posted June 8, 2012 Just as the topic says. I have a late '95 Impreza WITH a ODBII plug. (I know its ODBII, it tells me secrets). My question is, would it tell me the things I want to know? Biggest thing that is making me doubt is the fact that it is a early ODBII computer. Would it even tell me what i want. RPM, Fuel consumption, coolant temperature, engine speed, horsepower? Anyone? Bueller? -Justin Quote Link to comment Share on other sites More sharing options...
bstone Posted June 8, 2012 Share Posted June 8, 2012 I have one sitting in a bucket in the rear of my car. Ended up not using it at all. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 8, 2012 Share Posted June 8, 2012 You'll get the bare basics. RPM, ECT, TPS, MAP, MAF, O2 V, Calculated load, Fuel Trims, spark timing... that's about all the early OBD2 systems supported. There are other values that can be checked such as knock sensor input and certain emissions valves duty cycle if you have a program that can read straight from the ECU, but I don't think Scan gauge will do that. I could be wrong. How much is this thing? You can pick up an Equus Innova OBD2 scanner that reads live data, all the sensors mentioned above, and has built in OBD2 code definitions, and is updateable, and supports more manufacturer specific codes than pretty much any other readers on the market for around $140 from Amazon. If you have a smart phone, iPhone and Android platforms have OBD2 diagnostic Apps that can be downloaded and you buy a small Bluetooth transmitter that plugs into the OBD2 port. Then you can read/erase codes, view available live data and sensor outputs, freeze frames, and you can email snapshot or recorded live data to yourself, or anyone else for that matter, so it can be reviewed on a computer. Generally about $30 - 40 for the dohickie to plug into the car and you get the basic App for free. I bought the one for iPhone called BlueDriver, and the basic app is quite useful.You can read and erase DTCs, email them, and view some basic data. The whole program can be opened up for $50 IIRC, but you can also open up just one or two things at a time for only a few dollars. Quote Link to comment Share on other sites More sharing options...
danbennett2u Posted June 8, 2012 Share Posted June 8, 2012 I think it would work for what they advertise. It says it just has to be fully OBDII compliant, and the 95 subarus are. I dont think it uses manufacturer speciic info or advanced readings that were added later to get its readings since it says it works with 1996 vehicles. Quote Link to comment Share on other sites More sharing options...
crazyman03 Posted June 8, 2012 Author Share Posted June 8, 2012 I have one sitting in a bucket in the rear of my car. Ended up not using it at all. Would you part with it? What model is it? -justin Quote Link to comment Share on other sites More sharing options...
nipper Posted June 8, 2012 Share Posted June 8, 2012 If you have a smart phone, iPhone and Android platforms have OBD2 diagnostic Apps that can be downloaded and you buy a small Bluetooth transmitter that plugs into the OBD2 port. Then you can read/erase codes, view available live data and sensor outputs, freeze frames, and you can email snapshot or recorded live data to yourself, or anyone else for that matter, so it can be reviewed on a computer. Generally about $30 - 40 for the dohickie to plug into the car and you get the basic App for free. I bought the one for iPhone called BlueDriver, and the basic app is quite useful.You can read and erase DTCs, email them, and view some basic data. The whole program can be opened up for $50 IIRC, but you can also open up just one or two things at a time for only a few dollars. Where can i find of what thou speak? Quote Link to comment Share on other sites More sharing options...
danbennett2u Posted June 8, 2012 Share Posted June 8, 2012 Application is called Torque https://play.google.com/store/apps/details?id=org.prowl.torquefree&feature=search_result#?t=W251bGwsMSwyLDEsIm9yZy5wcm93bC50b3JxdWVmcmVlIl0. Search amazon or ebay for OBDII bluetooth and you will see the dongles. Quote Link to comment Share on other sites More sharing options...
nipper Posted June 8, 2012 Share Posted June 8, 2012 Any recomndations as they vary in price from 99 cents to 135.00 Quote Link to comment Share on other sites More sharing options...
crazyman03 Posted June 9, 2012 Author Share Posted June 9, 2012 That IS tempting, though I would like something that is always on in the car. the only problem is (from what i've read) is there is limated BluetoothODBII hardware that works with iPhones.. which is what i have. Nipper: http://www.amazon.com/Bluetooth-ELM-327-Diagnostics-Cable/dp/B004VXSH48/ref=sr_1_4?s=electronics&ie=UTF8&qid=1339205928&sr=1-4&keywords=bluetooth+odb2 video: -Justin Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 9, 2012 Share Posted June 9, 2012 Where can i find of what thou speak? BlueDriver for iPhone is downloadable through the iTunes App store. They have a website as well, http://www.Lemurmonitors.com Quote Link to comment Share on other sites More sharing options...
crazyman03 Posted June 9, 2012 Author Share Posted June 9, 2012 Have you used it before? Would it give me fuel consumption, temps, etc? Like the other "promises"? -Justin Quote Link to comment Share on other sites More sharing options...
