rllywgn Posted March 28, 2004 Share Posted March 28, 2004 I noticed that you had a set of hp coilovers on your car, just curious which car there actually meant for... wouldnt mind having a set for my wagon... thanks in advance Link to comment Share on other sites More sharing options...
subaru_styles Posted March 28, 2004 Share Posted March 28, 2004 the coilovers were for a 99+ jetta. 450lb springs in the front, 350lb in the rear. as far as the rear goes(dont use the sping cap) you can choose not to use adj. perch as the spring is nearly the same diameter as stock.depending on how low you want it. WARNING:to anyone using these type of sport coilovers beware. as i told shean, even though your car will not be "slammed" IT WILL ride like it!! Hitting dips in the road really "G forces" your butt into the seat. if any of you have ridden in a slammed #onda, you know the feeling. I do not suggest this for your daily driver. But if you want to handle 10X better and can live with the ride..... GO FOR IT! look i used bold, underline, and italic all in one post!hahahhaha Link to comment Share on other sites More sharing options...
88rxsedan Posted March 28, 2004 Share Posted March 28, 2004 is it a straightforward install, or custom parts required? info would be apreciated for my 4x4 scoob Link to comment Share on other sites More sharing options...
rallyruss Posted March 29, 2004 Share Posted March 29, 2004 wow I can imagin the ride must be really harsh. I have a 2002 jetta with coil overs here. when it was still alive rode rather stiff. thats on the jetta that weighs in a good bit heavyer than a sube. I will have to go look at both to do a little comparo. the little tab had to be ground off right? I have been involved in the droping of three jettas now so I know what you are talking about. you used the stock strut in the rear? sorry a little confused onthat part. Link to comment Share on other sites More sharing options...
The Scooby Posted March 29, 2004 Share Posted March 29, 2004 well from brads pictures it looks as if he just put the new coilovers over he stock shocks and struts. which is no problem. you just need a spring compresser to compress the spring so you can take it off, other wise your risk taking off a arm or legg when that tension is let off that spring. and i dont mind a harsh ride, my car is too soft for me, also, i had a lowered camaro, and trust me, i can handle the lowered ride. i like it. Link to comment Share on other sites More sharing options...
subaru_styles Posted March 30, 2004 Share Posted March 30, 2004 the only modification was to grind the lttle disk of on the front struts...if anyone wants a second opinion P.M. harpua (donny). he drove it this past weekend. Link to comment Share on other sites More sharing options...
harpua Posted March 30, 2004 Share Posted March 30, 2004 Second opinion: Wow, i didn't know that a subaru could handle like that....Driving straight was the times you could feel the *slammed* ride, but once I got into a corner it was like heaven on wheels.... I can see why subaru_styles presents a warning. But i can see at the same time why he wanted to do the mods he has done. There was little to no roll in the car when cornering. A world of difference from stock suspension. From the looks of it, i will be doing similar mods, although not as extreme as subar_styles, but close none the less....I was more than impressed by these mods. If anyone has any questions, feel free to PM me. And thanks again styles.... Link to comment Share on other sites More sharing options...
88rxsedan Posted May 18, 2004 Share Posted May 18, 2004 subaru_styles said: the only modification was to grind the lttle disk of on the front struts...if anyone wants a second opinion P.M. harpua (donny). he drove it this past weekend.what do you mean, grind the little disc off.. im sorry for sounding daft, but im interested in lowering my car and wanna make sure i get all the parts so i can just do it and have it done. i can only wish my car will look 1/4 as good as yours does though Link to comment Share on other sites More sharing options...
subaru_styles Posted May 18, 2004 Share Posted May 18, 2004 when you have the front struts off you cannot slide the threaded sleeve onto the bottom perch because there's is a ring of metal that is bigger diameter than the sleeve. that ring is right in the area of where the rod enters the strut. not a big deal. just a little grinding Link to comment Share on other sites More sharing options...
