greggbrat Posted March 28, 2004 Share Posted March 28, 2004 I want to put cruise control on my 87 RX turbo but I have heard that turbo manifold vacuum turns into positive pressure when the turbo kicks in and makes it unusable for most cruise control units. Now the questions is......how can I do it? I am not very knowlegeable about the inner workings vacuum on the RX but I thought there was a small vacuum pump under the hood near the passenger side strut tower......if that is the case can this be used to run an aftermarket cruise control? And does the 87 RX use a vacuum assisted brake booster? Hopefully this makes sense to someone because I claim total ignorance on this subject. Thanks, Gregg Link to comment Share on other sites More sharing options...
subaru_styles Posted March 28, 2004 Share Posted March 28, 2004 make sure to wire it right! ive seen a few cars with owners always having a dead battery. got checked out and that little aftermarket cruise control parasitic draw keeps draing the battery. installed by non metionable stereo shops Link to comment Share on other sites More sharing options...
greggbrat Posted March 28, 2004 Author Share Posted March 28, 2004 I do know all about electrical.......I will make sure I wire it to a source that turns on after the ignition is on. Thanks for the heads up. Link to comment Share on other sites More sharing options...
camosuba Posted March 28, 2004 Share Posted March 28, 2004 you could source a vacuum pump from a legacy they have them for the cruise independant of the manifold n/a or turbo camo Link to comment Share on other sites More sharing options...
greggbrat Posted March 28, 2004 Author Share Posted March 28, 2004 I did find an EA82 Turbo Wagon GL in the junkyard that has cruise control. (not sure if its factory or dealer installed) Would this vehicle also have a separate vacuum source for the vacuum pump? Or did it just tap into the vacuum pump above the passenger strut tower? My turbo RX has the same vacuum pump (above the pass strut tower) as the turbo wagon in the junkyard. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 28, 2004 Share Posted March 28, 2004 A lot of EA82T's, and even some EA81T's came with CC. I have an 85 wagon right now with CC. Works great I might add. GD Link to comment Share on other sites More sharing options...
