tomf31 Posted June 10, 2012 Share Posted June 10, 2012 I have a 96 outback with a 2.5 was running fine then it stalled now it won't start back up. I have no power to the coil at all new cam senser new crank senser new knock senser getting fuel good when first turn key on out of new filter. But have no power on any of the 3 wires at the coil with key on and cranking. all dash lights come on but the check engine light. Have searched on here and found nothing that has helped so far. thank ahead Link to comment Share on other sites More sharing options...
tomf31 Posted June 10, 2012 Author Share Posted June 10, 2012 I also checked I have no power at the box on the fire wall and all fuses are good under dash and under hood Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 10, 2012 Share Posted June 10, 2012 How many miles? How does the engine sound while cranking? Normal chug chug chug, or does it sound more like one long smooth woosh? Did you check the fusible link in the under hood fuse panel? Link to comment Share on other sites More sharing options...
mikaleda Posted June 10, 2012 Share Posted June 10, 2012 sounds like a fusible link. Link to comment Share on other sites More sharing options...
tomf31 Posted June 10, 2012 Author Share Posted June 10, 2012 Its normal turn over checked timing belt just to make sure its good just put on about 15000 miles ago. has 135000 miles on it the fuseable link in the fuse box under the hood is good is there any anywhere else? Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 10, 2012 Share Posted June 10, 2012 Assuming all of the big fuses in the under hood panel are fine (they can appear fine but you should remove them all one at a time and test them) the next step would be checking relays under the dash. The main relay gives power to pretty much everything when the key is turned. It's a big single pull double throw, will have 6 large wires going to it. Link to comment Share on other sites More sharing options...
Gloyale Posted June 10, 2012 Share Posted June 10, 2012 But have no power on any of the 3 wires at the coil with key on and cranking. all dash lights come on but the check engine light. Blown fusible link. The no CEL w/ key on is the giveaway. check the underhood fuse panel. Link to comment Share on other sites More sharing options...
tomf31 Posted June 10, 2012 Author Share Posted June 10, 2012 the fusable link under hood is good checked it and the fuses with a multi meter not sure if the check engine light even works need to check the bulb Link to comment Share on other sites More sharing options...
