I have a 96 outback with a 2.5 was running fine then it stalled now it won't start back up. I have no power to the coil at all new cam senser new crank senser new knock senser getting fuel good when first turn key on out of new filter. But have no power on any of the 3 wires at the coil with key on and cranking. all dash lights come on but the check engine light. Have searched on here and found nothing that has helped so far. thank ahead
Its normal turn over checked timing belt just to make sure its good just put on about 15000 miles ago. has 135000 miles on it the fuseable link in the fuse box under the hood is good is there any anywhere else?
Assuming all of the big fuses in the under hood panel are fine (they can appear fine but you should remove them all one at a time and test them) the next step would be checking relays under the dash. The main relay gives power to pretty much everything when the key is turned. It's a big single pull double throw, will have 6 large wires going to it.
Blown fusible link. The no CEL w/ key on is the giveaway.
check the underhood fuse panel.
