BoxersOnly Posted March 28, 2004 Share Posted March 28, 2004 Well, I've started putting the EJ25 together in the back of my Bug, and as it turns out I did not take enough pics of all the hoses and crap. So here it goes: What does this thing do, and where does it connect to ? I know it goes somewhere behind the intake (here): But which one (see arrows) ? Also, there is a hose that starts at the breather on each valve cover. Where are all these connections for ? And then there is this thing. Where does the long end of this tube go ? Thanks ! Rob. Link to comment Share on other sites More sharing options...
blitz Posted March 29, 2004 Share Posted March 29, 2004 Almost everything there looks to be asscociated with the PCV system. If you've discarded the original intake tract for purposes of the swap, then you might have to re-plumb some of this, rather than re-connect it. Each valve cover has a fresh air entry point (breather) which must be derived from a source of filtered air (post air filter). The 1/2" metal nipple looks like the PCV valve, which connects to a source of manifold vaccum. The tank looks like an oil catch-can, but since I don't have anything like this on my '02, I can't comment, ditto on the plastic pitchfork thingy. Well... don't know if that helped much :-\ Link to comment Share on other sites More sharing options...
