lostbrat Posted June 10, 2012 Share Posted June 10, 2012 driving in 2wd , heard a bang and now only drives in hi or lo 4wd ranges? 4wd shifter seems to operate properly. can this be fixed or do I need a New transmission.???? no noises from trans while driving now... Link to comment Share on other sites More sharing options...
kerandt Posted June 10, 2012 Share Posted June 10, 2012 Check you drive axles (front)! You won't go anywhere (unless in 4wd) if an axle / CV joint went out on the front. Link to comment Share on other sites More sharing options...
lostbrat Posted June 10, 2012 Author Share Posted June 10, 2012 i did not think of that. I gave my brat to my nephew and 6 days later he called telling me this is what hapenned. working on it tomorrow and sure hope its an axle??? thats easy fix... I have 2 spare transmissions so I am prepared to change that tomorrow.. I was thinking maybe something internal to 4wd shifter, because no strange noises, or so an 18 year old says??? Link to comment Share on other sites More sharing options...
bratman18 Posted June 10, 2012 Share Posted June 10, 2012 Yep, front cv axle went boom. I have had them break before and not even look like it too. All the broken parts stayed inside the boot. Link to comment Share on other sites More sharing options...
AKghandi Posted June 11, 2012 Share Posted June 11, 2012 Yep thats how i got my hatchie. In 2wd in gear foot off the clutch youll hear it rotating. Link to comment Share on other sites More sharing options...
lostbrat Posted June 12, 2012 Author Share Posted June 12, 2012 yup, it was the inner cv joint blown up... cup turned but axle shaft did not.. all fixed now... not sure how it broke but all the balls were in the boot. replaced it with another shaft I had and will use this one as a core some day Link to comment Share on other sites More sharing options...
