AdventureSubaru Posted June 11, 2012 Share Posted June 11, 2012 Searching rads and it's saying there's a difference between radiators between manual and auto radiators. What's the difference and how hard would it be to put a manual rad into an automatic car? Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted June 11, 2012 Share Posted June 11, 2012 Generic aftermarket are going to be for both. Either you connect the AT lines to the radiator if you have them or not for a manual. Quote Link to comment Share on other sites More sharing options...
AdventureSubaru Posted June 11, 2012 Author Share Posted June 11, 2012 I have a used rad from a manual. That would be a no-go to drop into an auto then? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted June 11, 2012 Share Posted June 11, 2012 I have a used rad from a manual. That would be a no-go to drop into an auto then? It needs to have the lines on the side for the auto tranny lines to go into the tranny cooler. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 11, 2012 Share Posted June 11, 2012 I have a used rad from a manual. That would be a no-go to drop into an auto then? if you have a used manual trans radiator: A.) if it's original OEM (most likely) then it won't have the transmission cooler lines in it. you can still use it if you install an aftermarket transmission cooler for $30, still cheaper than another radiator. i think this is the one i usually use: http://www.etrailer.com/Transmission-Coolers/Derale/D13311.html Subarus only need the smallest cooler you can find. wouldn't surprise me if those ones i've used are actually too big for the daily drivers i've used them on. but so far, so good. B.) if it's an aftermarket radiator it will have the transmission cooler lines on it - just look and see, we can't tell you that without looking at the radiator. just look - does it have tubes coming out of it or not? Quote Link to comment Share on other sites More sharing options...
Recian Posted June 11, 2012 Share Posted June 11, 2012 It doesnt seem to make much difference. The main difference is m/t wont have cooler lines. However most aftermarket sources produce one item to save money. If m/t doesnt have something a/t does they make the a/t one for both models and u dont use what u dont need i.e. the cooler. I have an auto radiator in my m/t 95 and have no issues from it. Quote Link to comment Share on other sites More sharing options...
