shuff Posted June 14, 2012 Share Posted June 14, 2012 will drive shafts from a 90's NA ej22 liberty (legecy) fit in a 98 2nd gen OUTBACK? im only interested in fronts Link to comment Share on other sites More sharing options...
ivans imports Posted June 14, 2012 Share Posted June 14, 2012 front cv fitts from 89-02 legacy / outback some may need the tone ring konked off Link to comment Share on other sites More sharing options...
shuff Posted June 19, 2012 Author Share Posted June 19, 2012 well it does fit, but i just swapped complete hub/control arm/drive shaft from the 98 outback in to my 90 liberty (legecy) Link to comment Share on other sites More sharing options...
JPX Posted June 19, 2012 Share Posted June 19, 2012 This is valuable information! I knew from my own recent experience that the knuckle/hub is identical between the 92 and the 96. So unless there was a wholesale change to the diff dimensions, I don't see why the geometry would be any different for the axle. Even the tone ring was identical. Thanks for sharing your findings! Makes for more options at the junkyard! Link to comment Share on other sites More sharing options...
shuff Posted June 22, 2012 Author Share Posted June 22, 2012 well heres some little pics, its only the rear mount that is a little differant Link to comment Share on other sites More sharing options...
