DavieGravy Posted June 14, 2012 Share Posted June 14, 2012 The alternator won't come up high enough to make the belt tight. Even if I run it all the way up. I can't figure this out. It's like the belt grew in size. Can anyone see anything that's wrong from the picture? Link to comment Share on other sites More sharing options...
johnceggleston Posted June 14, 2012 Share Posted June 14, 2012 wrong belt? did you count the ribs? is the belt new? the alt is all the way down, not up? Link to comment Share on other sites More sharing options...
coolskaterkid Posted June 14, 2012 Share Posted June 14, 2012 looks like the alt is all the way down not up. Link to comment Share on other sites More sharing options...
DavieGravy Posted June 15, 2012 Author Share Posted June 15, 2012 Thanks for the responses. I hadn't lined the groove up on the crank pulley before bolting it down. So it was nudged up a bit. I fixed the crank pulley and problem solved. Link to comment Share on other sites More sharing options...
