onyxyth Posted June 16, 2012 Share Posted June 16, 2012 (edited) I'm working on a '96 Subaru Impreza with the 2.2 EJ22, the rubber on the balancer was cracked and it'd been wobbling so I'm going to replace it as well as doing the timing and water pump. I picked up a decent looking balancer from the junkyard from a '97 outback (I think) with an ej22. These should be the same parts, right? They look very similar however I don't remember the old one having any "holes" on the front face (like these, however this isn't my picture) Unfortunately I don't have the old balancer to compare anymore. basically, will a balancer from a '97 legacy fit a '96 impreza? Any input? Edited June 16, 2012 by onyxyth Link to comment Share on other sites More sharing options...
uniberp Posted June 16, 2012 Share Posted June 16, 2012 onyxyth said: I'm working on a '96 Subaru Impreza with the 2.2 EJ22, the rubber on the balancer was cracked and it'd been wobbling so I'm going to replace it as well as doing the timing and water pump. I picked up a decent looking balancer from the junkyard from a '97 outback (I think) with an ej22. These should be the same parts, right? They look very similar however I don't remember the old one having any "holes" on the front face (like these, however this isn't my picture) Unfortunately I don't have the old balancer to compare anymore. basically, will a balancer from a '97 legacy fit a '96 impreza? Any input? More than likely it will fit, but if it's wobbling it's most likely the pulley has gotten loose. Lotsa threads here about fixing loose pulleys. Basically cranking it down 130 lb/ft. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 16, 2012 Share Posted June 16, 2012 Any EJ crank pulley will fit. They are all the same with respect to fitment. GD Link to comment Share on other sites More sharing options...
onyxyth Posted June 16, 2012 Author Share Posted June 16, 2012 Thanks for the replies guys. The previous pulley was wobbling because of the cracked rubber, it was visibly skewed. The new one is straight as an arrow. Good to hear it will fit, too. I appreciate the help, I'll have to keep this forum in mind as this car ends up in my garage pretty often, hah! Link to comment Share on other sites More sharing options...
edrach Posted June 17, 2012 Share Posted June 17, 2012 There seems to be a physical difference between the automatic and 5MT harmonic balancers but I've found they are all interchangeable. I'm not quite sure why there is a difference. I've tended to collect them at the pull a part yards just so I have a spare when I need it since the rubber does fail in these. Link to comment Share on other sites More sharing options...
Kingkoopa Posted March 13, 2015 Share Posted March 13, 2015 On 6/16/2012 at 4:09 PM, GeneralDisorder said: Any EJ crank pulley will fit. They are all the same with respect to fitment. GD Sorry for reviving a dead thread, but I figured it would be better than just creating a new one. I would just like to clarify. I need a new harmonic balancer/crankshaft pulley for my '94 Legacy L EJ22 asap. The only ones that are in stock in my area are for a '99 Legacy Outback EJ25. Will the EJ25 HB/Pulley work on my EJ22? Thanks very much. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 13, 2015 Share Posted March 13, 2015 yup! go for it. Link to comment Share on other sites More sharing options...
Kingkoopa Posted March 13, 2015 Share Posted March 13, 2015 Awesome. Thanks very much. Link to comment Share on other sites More sharing options...
