john40iowa Posted June 18, 2012 Share Posted June 18, 2012 '99 Forester A few weeks back a pedestrian and dog were in the middle of the road, strange since two perfectly good side walks were open. Anyhow on this road I had to take the shoulder area which was rather pot holed. Didn't appear all that extreme, but noticed there after a kinda of "Clunky sound" from the front end anytime a bump is crossed. I thought it might be the undercover, so I put new clips in that hold it on. No change:( The kyb struts have 50k and look fine as do the original springs. It was aligned about 5 months ago by a very good shop. It tracks and runs fine, and stops smoothly. Just this annoying plastic rattle trap sound at each bump, for lack of a better description. Any thoughts of the culprit here would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 18, 2012 Share Posted June 18, 2012 seems like crawling through potholes would put some stress on the front anti-sway bar and it's endlinks and brackets - definitely check that system out carefully. basically, all the suspension and steering needs to be examined. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted June 18, 2012 Share Posted June 18, 2012 ball joint / swaybar links Quote Link to comment Share on other sites More sharing options...
JPX Posted June 19, 2012 Share Posted June 19, 2012 My uncle had a bad curb hop mishap in a 2000-ish Toyota Camry. The rear sway bar popped out of the mounting clamp and bushing. Made a hell of a racket rattling around. Check your suspension components at the sway bars and control arms. The extreme force might have popped out a bushing or even the bar itself. Quote Link to comment Share on other sites More sharing options...
john40iowa Posted June 19, 2012 Author Share Posted June 19, 2012 This is good advice. Looked at the end links and they are fine. I need to remove the undercover and really take a good look at things. Thanks! Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 19, 2012 Share Posted June 19, 2012 bad top hat at top of strut?? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 19, 2012 Share Posted June 19, 2012 bad top hat at top of strut?? good post - even rebound may have busted one of those 3 little studs too. Quote Link to comment Share on other sites More sharing options...
john40iowa Posted June 20, 2012 Author Share Posted June 20, 2012 Don't Know if it is a factor, but discovered the tires were all overfilled; the fronts have something near #40psi. No I didn't do it, I know they are supposed to be in the neighborhood of 28-32 psi from the door panel. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 20, 2012 Share Posted June 20, 2012 Don't Know if it is a factor, but discovered the tires were all overfilled; the fronts have something near #40psi. No I didn't do it, I know they are supposed to be in the neighborhood of 28-32 psi from the door panel. I suppose it's 'possible' the suspension/steering gear could have received more shock than if the tires were a little softer. might never know. They definitely would transmit 'NVH' (noise, vibration,harshness) more at 40 than at 30. A lot of people run their tires 10-15% over so, 40 isn't 'crazy' high. I usually set mine about 3 psi over, figuring they'll be low for a awhile before i check them again. If you really do consistently run tires at 40, handling might suffer a little, and they will wear in the middle faster than the shoulders. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted June 21, 2012 Share Posted June 21, 2012 have been puting all awd subarus at 35 front and 32 rear to compansate for engine wheight so get no windup Quote Link to comment Share on other sites More sharing options...
Recian Posted June 21, 2012 Share Posted June 21, 2012 This happened to my 95 impreza after i smashed the front end into a mud hole. My LF control arm rear bushing is leaking grease now. Pops whenever i accelerate. Check those bushings. Theyre servicable seperate from the arm on older subys Quote Link to comment Share on other sites More sharing options...
john40iowa Posted June 30, 2012 Author Share Posted June 30, 2012 The car went to the good shop today and we got the answer. It confounded the mechanic, who thought it was the strut tower; a closer look revealed it be an issue with the hood. Apparently it was loose and had be tightened a bit... go figure. Quote Link to comment Share on other sites More sharing options...
Recian Posted July 1, 2012 Share Posted July 1, 2012 at least you got it resolved. My noise at take off is still there. It's worse now that i replaced my motor mounts. Quote Link to comment Share on other sites More sharing options...
