iluvdrt Posted March 28, 2004 Share Posted March 28, 2004 hello, everyone. i recently have been hearing a popping noise when ever i stop and go. i know its not the cv, because they are new and the sound isnt coming from that area. it sounds like its coming from the consol area and can be felt through the passenger floor board. i checked underneath the car for loose tranny mounts, crossmember bolts, and trac bar rigity, and all seems to be in good shape. the control arm bushings seem tight as do the ball joints. i am really stumped on this one. any ideas? it does appear one of motor mounts may be going, but would this make that noise? it does it no matter how hard i accelerate or stop. thanks. Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 28, 2004 Share Posted March 28, 2004 You might want to check your sway bar mounts. Sometimes if they start to come loose, they will make a "popping" noise like you described. Even if they look to be on there, try to tighten them with a wrench. I know I've driven a car with a loose sway bar bushing in the rear and it was making a popping noise too. Just my $.02:D Link to comment Share on other sites More sharing options...
iluvdrt Posted March 28, 2004 Author Share Posted March 28, 2004 never thought of that. ill check. thanks, any others. Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted March 29, 2004 Share Posted March 29, 2004 it does sound like the motor mount Link to comment Share on other sites More sharing options...
iluvdrt Posted March 29, 2004 Author Share Posted March 29, 2004 but why would it sound like its in the consol, and also when i stop? i have never had a motor mount make noise like this. Link to comment Share on other sites More sharing options...
ShawnW Posted March 29, 2004 Share Posted March 29, 2004 Is your shifter really sloppy? It might be the cushion rubber thing that holds the shifter. Link to comment Share on other sites More sharing options...
iluvdrt Posted March 29, 2004 Author Share Posted March 29, 2004 my shifting is pretty good, but im beginning to think its something of the like. i will check the sway bars as mentioned above, and also take a better look at the shifter. it is a very loud noise, it sounds like the car is going to break in half. it hasnt hindered performance though. Link to comment Share on other sites More sharing options...
bushbasher Posted March 29, 2004 Share Posted March 29, 2004 this is the race wagon right? so its only 2wd? I was going to say driveshaft but then realized I take 4wd for granted Link to comment Share on other sites More sharing options...
mtsmiths Posted March 29, 2004 Share Posted March 29, 2004 My '87 has been doing this for over a year, and we can't find it either. That said, it's been over 15,000 miles and it hasn't goten any worse or shown any other symptoms, other than the exact thing you are describing. Link to comment Share on other sites More sharing options...
baccaruda Posted March 29, 2004 Share Posted March 29, 2004 it might just sound like it's coming from the console because that's the easiest place for the sound to transmit into the car. did you check the transmission crossmember as well? and see if the exhaust is still mounted and fastened properly and not rubbing on anything. Link to comment Share on other sites More sharing options...
iluvdrt Posted March 29, 2004 Author Share Posted March 29, 2004 bushbasher said: this is the race wagon right? so its only 2wd? I was going to say driveshaft but then realized I take 4wd for granted no its 4wd, but it is the race wagon. ok, i checked the sway bar and its ok too. i am thinking it is a bushing, but because i obviously dont excert as much force as the engine, i cannot simulate it. i am really leaning towards the bushings in the tranny x member of the passenger trailing arm. Link to comment Share on other sites More sharing options...
