Loyale 2.7 Turbo Posted June 23, 2012 Share Posted June 23, 2012 (edited) The Ignition Module is the Electronic Part that Substituted the Points inside the Distribuitor; it usually consist in two parts: One Pick up the Signal and the other sends the Pulses to the Ignition Coil.How you Test an Ignition Module?This Test was Done with the Nippon Denso Distribuitor, from a Carburated EA82 Subaru Engine, from the 2WD version; but this test is pretty Standard. This is the Nippon Denso Distribuitor, without its Cap, so you can see its Interior: The Red Part is the Rotor, while the Two Black plastic covers under it, hides the Two Parts that conforms the Ignition Module, they only have two Wires Between them and other two wires that goes outside from one of them, to the Ignition Coil. To do the Test, You'll Need: - A Good 12V Battery and Jumper Wires to use its Power.- The Distribuitor with its Rotor & Ignition Module inside.- The Ignition Coil.- A Sparkplug's Wire.- A Sparkplug.The Distribuitor has two Wires that comes from the Ignition Module, one is Black with White Stripe, this is the Positive (+) while the Yellow one is the Ground (-) or Negative one. The Easy Test Procedure goes as Follows: If you Turn Manually the Distribuitor's Gear under it, Two things Might Happens:► Sparks on the Sparkplug = Means a Good Ignition Module.► No Sparks on the Sparkplug = Means a Dead Ignition Module.But you MUST Double Check that you have done Right the Connections.I Hope this can Help.Kind Regards. Edited November 4, 2014 by Loyale 2.7 Turbo 3 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 23, 2012 Author Share Posted June 23, 2012 (edited) As far as I Know, the carburated EA82 Engines on the 2WD (front wheel drive Only) models, came with the Nippon Denso Distribuitor, while the carburated EA82 engines on the 4WD Models, came with the Hitachi Distribuitor.The Nippon Denso Distribuitor on the 2WD Models, has a Faster acceleration advance curve, than the Hitachi Distribuitor on the 4WD Models.Both distribuitor's Ignition Modules are very different from each other, the Hitachi distribuitor has a Single piece Module, while the Nippon Denso distribuitor has a two parts' module, it has Two Wires Between them and Two Wires Goin' out from them, out from the Distribuitor to the Ignition Coil.For the Nippon Denso Distribuitor, the Ignition Module has the Followin' part Numbers:► The Nippon Denso Part Number is: 1313000500► The Subaru Part Number is: 22183 AA040This is How it Looks:Aftermarket part Numbers for the Same Ignition Module, are:► Transpo (Brand): NM 500► Mobiletron (Brand): IGT 010► GoodWay (Brand): GW-M500► Beck Arnley (brand): 180-0245This is a Picture of my Brand New "Beck Arnley" Ignition Module,just out of its Box as it Came from RockAuto:Kind Regards. Edited April 11, 2013 by Loyale 2.7 Turbo to add more info 2 Link to comment Share on other sites More sharing options...
