mikaleda Posted July 26, 2012 Author Share Posted July 26, 2012 finally got my struts in (sorry no pics at the moment) i had to end up using my old mounts and bearings. rock auto customer service is great after the parts they sent me failed in every way imaginable, and even after i did a little welding on them they are still going to refund me the money for them and are sending me return instructions today . now all i have to do is put my ball joint in and i can test out my new struts:D Link to comment Share on other sites More sharing options...
mikaleda Posted July 26, 2012 Author Share Posted July 26, 2012 pics! not much just thought i would put up some pics of my new kybs next time i am going to spend the money to have a shop switch the springs. i was using a cheap spring compressor and they didn't work very good after a few hours of cussing i got the assembly's back together and in my car i can hardly wait to try them out. Link to comment Share on other sites More sharing options...
O.C.D. Posted July 29, 2012 Share Posted July 29, 2012 So those KYB's were direct replacements then. That is good news. I am gonna have to snag a set for my Brat now, lol. Thanks for sharing all the info for us. Link to comment Share on other sites More sharing options...
mikaleda Posted July 29, 2012 Author Share Posted July 29, 2012 yep they fit perfect but just so you know when i ordered the mounting kits from rock auto they were in worse shape than my old mounts were and they didn't fit anyway so be careful if you are buying new mounts and bearings. Link to comment Share on other sites More sharing options...
mikaleda Posted July 29, 2012 Author Share Posted July 29, 2012 (edited) - Edited July 30, 2012 by mikaleda Link to comment Share on other sites More sharing options...
O.C.D. Posted August 1, 2012 Share Posted August 1, 2012 yep they fit perfect but just so you know when i ordered the mounting kits from rock auto they were in worse shape than my old mounts were and they didn't fit anyway so be careful if you are buying new mounts and bearings. Thinking of just reusing the old ones. I didn't even consider replacements as far as mounts and bearings go. hmmmm. Link to comment Share on other sites More sharing options...
mikaleda Posted August 2, 2012 Author Share Posted August 2, 2012 i used my old mounts and they worked just fine. Link to comment Share on other sites More sharing options...
O.C.D. Posted August 5, 2012 Share Posted August 5, 2012 So I took a gamble with the Monroe's and that part number is wrong for a 1980 brat. Needs the shaft mount and not the ears type. Dang it all anyway. Just tout I would roll the dice. FYI to anyone else on the Monroe 4915 and gen 1 brats. Link to comment Share on other sites More sharing options...
mikaleda Posted August 5, 2012 Author Share Posted August 5, 2012 (edited) according to rockauto.com they should be right, all the small pick-ups i have worked on have this style shock. in fact i have never seen any 80's subarus with anything other than this style shock either. Edited August 5, 2012 by mikaleda Link to comment Share on other sites More sharing options...
O.C.D. Posted August 16, 2012 Share Posted August 16, 2012 Do your front struts look like this with these bolts? Did that portion get moved over to the new KYB struts you bought? Link to comment Share on other sites More sharing options...
TheLoyale Posted August 16, 2012 Share Posted August 16, 2012 (edited) OCD, those are the spring perch adjustment bolts (Adjustable ride hight) If you were to buy new struts for an EA81 car, you will be getting ones that are not adjustable but are pre adjusted to sit at the factory max hight. So no, KYBs will not have those bolts. This is what they look like before and after adjustment. Edited August 16, 2012 by TheLoyale Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 16, 2012 Share Posted August 16, 2012 thanks TheLoyale now i know how to adjust the sespension so my peugeots wont rub:clap: Link to comment Share on other sites More sharing options...
O.C.D. Posted August 16, 2012 Share Posted August 16, 2012 Ah, bless PB Blaster, lol. Thanks for the info TheLoyale. I should have looked more intently. Seems like the KYB's will work then. So really if one wanted to lower their front with the KYB's they could lower the spring bucket... hmmmmmm Link to comment Share on other sites More sharing options...
TheLoyale Posted August 16, 2012 Share Posted August 16, 2012 The spring perch is welded obviously, so thats really not an option unless you want to cut and weld (Which may boil the damper fluid) You might be able to retro fit different model Subaru struts in there to lower the front, I want to say 2WD struts might lower it (Don't quote me on that) The rear torsion tube is also adjustable, there is one large bolt (17mm) on top of the center of the tube. PB Blaster is your friend! Link to comment Share on other sites More sharing options...
O.C.D. Posted August 16, 2012 Share Posted August 16, 2012 Ok so now that I have completely pirated this thread,......lol Looks like the KYB's in this thread are not going to work for the gen 1 brat as they are to dis-similar. The spring perch is too wide for the gen 1 Brat spring and apparently that nut on the top of the strut shaft is the wrong dimension for them. But Mikelada, on your wagon it worked. Link to comment Share on other sites More sharing options...
mikaleda Posted August 17, 2012 Author Share Posted August 17, 2012 whew after an exhausting week in washington, i now managed to crumple the right front end of my car with a red honda . but i was able to fix the damage well will get some pics up in a while sorry no before fix pics just after but i can tell you i hit hard enough to shove my fender into my tire. Link to comment Share on other sites More sharing options...
mikaleda Posted August 18, 2012 Author Share Posted August 18, 2012 (edited) pics after wreck http://i685.photobucket.com/albums/vv218/mikaleda/DSCI0006.jpg http://i685.photobucket.com/albums/vv218/mikaleda/DSCI0005.jpg Edited August 18, 2012 by mikaleda Link to comment Share on other sites More sharing options...
mikaleda Posted August 18, 2012 Author Share Posted August 18, 2012 patched the hole in my floor board with mini tech screws and some galvie tin. sealed it with old school roofing tar that stays flexible Link to comment Share on other sites More sharing options...
mikaleda Posted August 18, 2012 Author Share Posted August 18, 2012 oh ya almost forgot i found the problem with my cyclops light. when i pulled the bumper i noticed the limiter switch is corroded, bad. it looks like i will need a new one if i want to fix it Link to comment Share on other sites More sharing options...
mikaleda Posted August 24, 2012 Author Share Posted August 24, 2012 decided to quit working on this car for a while and start working on my legacy, so no new updates for a little while. Link to comment Share on other sites More sharing options...
mikaleda Posted November 25, 2012 Author Share Posted November 25, 2012 I am sorry to say this is the end of this thread I can't afford this car to many things are going wrong my legacy finally showed me definitive proof that it has a blown head gasket. This thing just has to many things wrong with it to use for a daily driver so I am going to sell it and put the money into my legacy I should be able to get enough out of it to put head gaskets timing belt and a nice set of tires on my legacy. ::horse: Link to comment Share on other sites More sharing options...
O.C.D. Posted November 26, 2012 Share Posted November 26, 2012 Find something else to sell. You will regret losing this car!!! Link to comment Share on other sites More sharing options...
mikaleda Posted November 26, 2012 Author Share Posted November 26, 2012 If I can find a way to get it going good enough to go down the road I might just keep it. I was just looking in a old shop Manuel for imports of that year and it told me how to fix the front end. I also noticed when I was looking at the suspension section That you can change the ride height in the back. Link to comment Share on other sites More sharing options...
belacane Posted November 27, 2012 Share Posted November 27, 2012 Find something else to sell. You will regret losing this car!!! Ditto that. What a neat car! Don't sell it. You'll pull thru. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted November 27, 2012 Share Posted November 27, 2012 i like this wagon too but it might be scary to find all of the places that have rusted through considering parts of the rockers are gone and the doors are starting so think of the wheel wells and under carriage, so it might be best to sell but i was looking forward to seeing the rust go away and the wagon get finished:(also this one is somewhat rare from the third eye and i think the orange dash lights are rarer than some other odometers and this one is one of the first ea81 body style cars around but the rust and body damage will make its value go down but the new suspension parts will make it worth something Link to comment Share on other sites More sharing options...
