bakerman1 Posted June 26, 2012 Share Posted June 26, 2012 I had a mechanic fix my heater valve on my heater. When I got it back every once in awhile while I'm driving my fasten seatbelt light will come on for about 10 secs and then go off. I talked to my mechanic and he said he didn't touch anything that would effect that. What might cause this issue? Thanks for the help Ken Link to comment Share on other sites More sharing options...
a2labs Posted June 26, 2012 Share Posted June 26, 2012 What year and model is your soob? I can only speak for the old ones. On older cars in general, there's a switch in the buckle, two wires that run down under the carpet under the seat, there's a connector there, I'd check that first... If it's got automatic seatbelts that slide along the top of the window, that might be a little more difficult to check... I'd pull the bulb in the instrument cluster, but I'm a cheapskate... and also a fan of common sense... my thinking is do you really need a light to remind you to buckle up... like you're not going to notice a big double strap across your body? just my 2 cents tho. Link to comment Share on other sites More sharing options...
bakerman1 Posted June 26, 2012 Author Share Posted June 26, 2012 Lol very true. I have 82 Subaru Brat. I can check the wires and see if there is an issue there. Ken Link to comment Share on other sites More sharing options...
